3g alt problem
  • Thread starter Thread starter MattTheBat83
  • Start date Start date Jul 9, 2007
M
MattTheBat83
203
  • Jul 9, 2007
i spliced the white and black wire from the original harness to the the small white and black wire from the 3g alt and i ran a wire with a fuse to the starter solenoid. the gauge in the car shows low amps and the battery only reads 12.3 with the car running. the two orange and black wires from the original harness are just supposed to be cut and capped off right?
M
MattTheBat83
203
  • Jul 9, 2007
what side of the starter solenoid you put the wire to?
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Jul 9, 2007
  • Jul 9, 2007
http://forums.stangnet.com/showthread.php?t=646825
M
MattTheBat83
203
  • Jul 9, 2007
thats what i went off of am i missing something
HISSIN50
34
129
Jul 9, 2007
  • Jul 9, 2007
Do you have a stator wire connection on the 1-wire male spade terminal on the 3G case?
M
MattTheBat83
203
  • Jul 9, 2007
which wire is the stator?
HISSIN50
34
129
Jul 9, 2007
  • Jul 9, 2007
On the D-shaped connector (that you do NOT plug into the new alternator. It has the two weak charge wires and one wht/blk stator wire), you splice into the stator wire in that plug, and run it to the one-wire connection on the new alternator (that one-wire port is at about 12 o'clock on a Mustang 3G). If you do not have a stator wire connected to this port, the alt won't work too well.
bobbyd
312
San Antonio/Los Angeles
Jul 9, 2007
  • Jul 9, 2007
hey hissin do you think a 3g wuold be enough to handle pullies and say a 1000w audio system? if so how many amp 130? 140? etcor should i just go ahead and get a 6g
HISSIN50
34
129
Jul 9, 2007
  • Jul 9, 2007
Honestly, I'm not much of a stereo guy (I like big sound but it costs big bucks). In the systems I've seen (I enjoy looking because I like clean, well-done wiring), they all run 160+ amp alts and caps. Recently I've seen some gripes that people have not had good luck with 200 amp alts, so it might be worth some research to find out failure rates with those.
Otherwise, all the big stereo folks are much better equipped to answer that than I am.
EDIT: I should add that I run a couple of subs and amps (in the 1K RMS range, no caps) with a 160 amp alt and E-fan. It does alright.
Good luck.
bloopbloob
578
Alberta
Jul 9, 2007
#10
  • Jul 9, 2007
  • #10
bobbyd
i think it would be plenty. i used to run 2 digital alpine amps 500W RMS each (1 for 4x12" JL subs and 1 for infinity interiors all around), with a capacitor, off my stock alt. it was def. not ideal, and i did get dimmed headlights on bass hits and occasional dead batteries, but it got by. i've since ditched the system, ran the stock alt for a while after, but still got dead batteries upon occasion, and low voltage on the guage. i got tired of this, and finally went 3g. huge difference! it puts out WAY more than stock, so i think you'd be fine.
bobbyd
312
Jul 9, 2007
#11
  • Jul 9, 2007
  • #11
coo thanks guys. yea thats the problem i have with the stock alternator that it kills my battery and that i get dimmed lights. even though i have a capacitor on there another problem that i have is that since my door handles are shaved i have to open them with the remote but somethings the battery is dead that i have to go through the hatch. i will get me a 3g then hehe i will look for one locally and get started on that system would cosist of the following.
1000watt amp to 2 10s. 250w amp for the rear speakers and a crossover and also a capacitor.
H
HaynStang
124
Portland
Jul 9, 2007
#12
  • Jul 9, 2007
  • #12
I think a stock 130amp 3G would be fine for a 1000 watt stereo system. I had about a 775 watt system in my '95 Crown Vic with a stock 130 amp alt and it worked fine. The amps I was running weren't especially efficient and I wasn't using a cap. I only got very very mild headlight dimming on bass hits at max volume.
bobbyd
312
Jul 9, 2007
#13
  • Jul 9, 2007
  • #13
coo thanks for the info i guess that made up my mind 3g it is
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
