I've been reading up on how 2 do the swap. But.. it seems 2 me that there diffirences in how 2 do the swap in each others write-ups..
So, from what I gather I need n what I need 2 do is:
-3g 200amp alt. Is this a good 1:
http://cgi.ebay.com/ebaymotors/ws/e...Track=true&ssPageName=VIP:Watchlink:middle:us
-Cut the alt. bracket.
-250amp fuse
-4ga. wire. Install the 250amp fuse within 18" of the "alt.", then go 2 the solenoid.
-4ga. ground wire from the block 2 the chassis. Do I need just 1 4ga. ground wire? or Should I change all of the grounds to a 4ga. wire?
-Splice the stator wire 2 the "small" wire on the "factory 3-wire power plug".
-Plug in the "factory" 3-wire plug into the alt. I've read that the foxes 3-wire Alt. plug is diffirent then the 3g's Alt.!?! N that I would need 2 buy a 3-wire Alt. plug from a 94'-95' GT!?!
-Plug in the stator. But dont plug in the factory 3-wire power plug... Just tape it up 2 seal it off n out of the way...
So, do I have all that right!?!
Thanx
-250amp fuse
Thanx
