3G swap
  • Thread starter Thread starter Shaolin Crane
  • Start date Start date Aug 22, 2009
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Aug 22, 2009
  • Aug 22, 2009
alright ive been reading wiring diagrams and posts for 5 hours now and im just confused, i got an alternotor all mocked up and ready to go and im trying to figure out the easiest way to do the wiring, i have spliced the white/black wire to the new plug on the 3G, now i need to know what wires i splice into next and where, i keep seeing that i need to put some yellow wire in the power post but dont know where to cut im tired and hungry and want to get this done asap help is appreciated
TechSteele
60
North Coast
Aug 23, 2009
  • Aug 23, 2009
I just got done doing a 6G install on my 89'
This web site below helped me understand the wireing better.
They explain 1g-7g
links>
3G install How to
Diagrams n Pics
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Aug 23, 2009
  • Aug 23, 2009
5 hours!? lol, all you gotta do is run a 4ga wire from the stud on the back of the wire to the starter solenoid w/ a inline fuse, and if you already have the stator wire spliced and plugged in thats it!! You shoulda been done 4 1/2 hours ago.
Thanks to Joe this is the only diagram you should need.
Dont let all the wires confuse you, all you gotta do is look what side the power wire from the alt goes on the solenoid
(Make sure your ring terminal on the stud isnt touching the alternator case because you will short it and blow the fuse, I did this without noticing the terminal was touching the case, not much clearance, use tape.)
http://www.stangnet.com/mustang-forums/646825-3g-alternator-install-how.html#post6673702
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Aug 23, 2009
  • Aug 23, 2009
what makes me nervous to cut anything when you've read 10 different ways, anywho i think i figured it out
HISSIN50
34
129
Aug 23, 2009
  • Aug 23, 2009
Jrichker's diagram in Mob's post is a real easy way to do it. You don't even have to cut the wire - bare a portion and solder a tee into it. Or feel free to cut - that rectifier plug should have been replaced about 10 times by now.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Aug 23, 2009
  • Aug 23, 2009
yeah when i saw how many different versions there were i just wanted to make sure, and being partially color blind i have never liked wiring
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
