- Apr 26, 2004
- 373
- 0
- 0
Predator r50c
Thanks! I think that might be a solution until they update. If you want, you can email me the r50c file. Will it work with my GT since you have a Mach? I know the Cobra's predator is different, so I wasn't sure about the Mach since it's a 4 valve.
PM me and I'll drop you my email (unless it's in my profile, I've forgotten). Thanks.
Edit: it is correct in my profile, but here it is anyway since you need to attach a file: [email protected]
Give Me TP said:If you want all the automatic transmission settings to be stock set your Predator to manual. That way there will be no automatic transmission settings loaded. The ability to adjust the factory HP tune for speedometer correction using 4.10 gears works fine on my Predator with revision r50d, I did not know Diablo had a glitch with it. If you want to try r50c I can e-mail it to you. It allows for adjustments to the factory tune also.
Is there a mod that makes the transmission smooth when letting off the gas? That's one thing I noticed about the 4.10s is they like to make the tranny "hang on" to the gear after letting off the gas. Almost like the tranny expects the car to be heavier so that it keeps pulling ahead more or something. I know that is because the RPMs are higher from the 4.10 rear, but it would seem the computer would know to "let go" when I let off the gas. It will let go eventually, but only around 3-5 seconds later, depending on how fast I'm going. I'm talking about cruising speeds (45-60 mph).
