4.10 gears
You'll get better acceleration with them - BUT you need a chip or tune to correct the shift points with the tranny. The 4.10s will throw those off - and you may hit the rev limiter on shifts.
Be sure to have a good shop do the gear install.
Good Luck!
Don
Good Luck!
Don
I already got the chip programer thing. The shop that is doing them is run by guys who only do stuff on mustangs and thats all they own. They also will said they will tune it for me after they do the gears.
Use Mobil 1 synthetic gear oil... 75w-140
Buy a bearing kit as well. Motive sells one for less than $100...
sgarlic said:
You can expect it to shift a lot sooner, have a little more RPM's at highway speeds, but nothing bad.. your MPG may drop 1 or 2.
I think you meant to say that it will shift later as the point of going with steeper gears is to reach the power band before shifting under acceleration.
