  • 1994 - 1995 Specific Tech
4.10 HELP
  • Thread starter Thread starter Blackened302
  • Start date Start date Feb 18, 2007
1 of 2 Next Last
Blackened302
1,439
South TX
Feb 18, 2007
  • Feb 18, 2007
hey guys, i need some help figuring out what's wrong w/ the 4.10 installation.
as we were assembling everything, we noticed that the pinion had some play in it.
we couldn't get the old pinion bearing off the old pinion, so i went to Advance and got a new one. we didn't think that they would be different, so we didn't measure them. could that be the problem?
we also used the same crush sleeve that was on the original pinion. could it not be long/short enough?
from what it looked like, the reason for play in the pinion was because it was not making enough contact w/ the ring, hence why we think the CRUSH SLEEVE or BEARING length has something to do with it... moreso the sleeve for not pushing the pinion in far enough (or whatever it does) so it could make enough contact w/ the ring and not have any play in it.
the gears i bought used (in good shape) and the only thing that came in the package was the ring and pinion--no bearings or crush leave, nothing. they are ford, too.
do they come with anything (crush sleeve, pinion bearing) when bought new?
do i need a longer crush sleeve or pinion bearing? help, please--need the car on the road ASAP.
thanks.
eagleautosports
139
Mebane NC
Feb 18, 2007
  • Feb 18, 2007
I think it's the crush sleeve. It should be replaced everytime the pinion gear is changed so check that out. You can buy an install kit that has the crush sleeve in it or the deluxe kit that has the wheel bearings too.
M
miller92063
253
Nebraska
Feb 18, 2007
  • Feb 18, 2007
Once the crush sleeve is crushed , it should not be reused
Blackened302
1,439
South TX
Feb 18, 2007
  • Feb 18, 2007
it wasn't damaged, though, so we didn't really think twice about re-using it.
can i buy a crush sleeve alone?
trav_19
810
Jackson, MI
Feb 18, 2007
  • Feb 18, 2007
i dont think you can get just the crush sleave i think you have to get the rear end maitence kit it come in it
drakesdad
961
Oregon OHIO
Feb 18, 2007
  • Feb 18, 2007
M
miller92063
253
Nebraska
Feb 18, 2007
  • Feb 18, 2007
Yes, you should be able to get them from summit or maybe even local parts stores
M
miller92063
253
Nebraska
Feb 18, 2007
  • Feb 18, 2007
definitely from summit though. like $5
Blackened302
1,439
South TX
Feb 18, 2007
  • Feb 18, 2007
thanks, guys.
i'd like to be sure, though, so could someone explain why a crush sleeve cannot be re-used and how a new (and assuming the correct size one) will fix the free play in the pinion? thanks!
drakesdad
961
Oregon OHIO
Feb 18, 2007
#10
  • Feb 18, 2007
  • #10
I got mine from the local Ford dealer
Blackened302
1,439
South TX
Feb 18, 2007
#11
  • Feb 18, 2007
  • #11
hang on a tick--i think i see what you mean about not re-using the crush sleeve.
the summit pic shows it wider than mine was--meaning mine was already crushed, literally. the uncrushed sleeve should provide the slight extra width we need to get the pinion to sit more on the ring, getting rid of the free-play.
am i correct?
M
miller92063
253
Nebraska
Feb 18, 2007
#12
  • Feb 18, 2007
  • #12
the cruch sleeve may have collapsed further with the last gears than it needs to with the new gears, leaving the sleeve pointless for the new gears.
sometimes i confuse myself.
M
miller92063
253
Nebraska
Feb 18, 2007
#13
  • Feb 18, 2007
  • #13
correct.
the sleeve does get literally CRUSHED
trav_19
810
Jackson, MI
Feb 18, 2007
#14
  • Feb 18, 2007
  • #14
yep when you install it its like a custom fit for your gears..
drakesdad
961
Oregon OHIO
Feb 18, 2007
#15
  • Feb 18, 2007
  • #15
exactly
Blackened302
1,439
South TX
Feb 18, 2007
#16
  • Feb 18, 2007
  • #16
sweet! thanks a lot, gentlemen!! gonna order this and have it shipped asap--i need my car on the road.
the free play in the pinion freaked us out...we were just about to bolt the cover up and add the new lube and take it for a spin, hehe.
thanks, guys!
drakesdad
961
Oregon OHIO
Feb 18, 2007
#17
  • Feb 18, 2007
  • #17
good luck Paul...keep us posted.
trav_19
810
Jackson, MI
Feb 18, 2007
#18
  • Feb 18, 2007
  • #18
thanks, guys!
i can see you guys sitting behind the car going...umm maybe its supposta be that way... (and this comment from the guy who dosent own the car) ummm lets just see what it does lol....
M
miller92063
253
Nebraska
Feb 18, 2007
#19
  • Feb 18, 2007
  • #19
just take her round the block right quick
Blackened302
1,439
South TX
Feb 19, 2007
#20
  • Feb 19, 2007
  • #20
edit
1 of 2 Next Last
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
