hey guys, i need some help figuring out what's wrong w/ the 4.10 installation.
as we were assembling everything, we noticed that the pinion had some play in it.
we couldn't get the old pinion bearing off the old pinion, so i went to Advance and got a new one. we didn't think that they would be different, so we didn't measure them. could that be the problem?
we also used the same crush sleeve that was on the original pinion. could it not be long/short enough?
from what it looked like, the reason for play in the pinion was because it was not making enough contact w/ the ring, hence why we think the CRUSH SLEEVE or BEARING length has something to do with it... moreso the sleeve for not pushing the pinion in far enough (or whatever it does) so it could make enough contact w/ the ring and not have any play in it.
the gears i bought used (in good shape) and the only thing that came in the package was the ring and pinion--no bearings or crush leave, nothing. they are ford, too.
do they come with anything (crush sleeve, pinion bearing) when bought new?
do i need a longer crush sleeve or pinion bearing? help, please--need the car on the road ASAP.
thanks.
thanks.
exactly
