menasci said:What???? 2600rpm at 80mph???![]()
Check again.
80 mph is more like 2900rpm
He is ok! I tack 3000 RPM'S @ 90MPH on a 2003 gt with a 3650 trany.
Check again.
jrc_03_gt said:![]()
Are you at 3000 RPM'S @ 90 MPH?tucker-tx said:Thanks,
I thought I had seen a previous post you had made, mentioning the 3000 RPM at 90 MPH. That is one reason I actually went ahead and went with the 4.10s instead of 3.73s. So while driving tonight hitting just under 2700 @ 80 didn't seem bad at all. Whatever. Your reassurance has helped. Thanks..
jrc_03_gt said:Are you at 3000 RPM'S @ 90 MPH?![]()
tucker-tx said:No, I was referred to a guy by a sales associate at Dallas Mustang, he did it at his house, and I had my car back in less than two hours. Let me know if you need some more info.
Cavallo said:Still scared to try that gear with my 02 Auto.
Was thinking 3.55 for more top speed.
If you go here:
http://www.wcfords.com/stuff/calcs/EGTcalc/egtcalc.php
4.10 put you at 100 in third !! Not good at the track.
Auto, 275/40R17 tires
menasci said:The diff. between the 2 trannys rpm's are not that much different.
They are almost identical.
Nuar said:Off topic a little bit.
Where is a good place to get the gears for as cheap as possible?
I wanted to get them for a while now, and this thread just convinced me to get 4.10s instead of the 3.73s![]()
