  • SN95 4.6L Mustang Tech
4.6 A/C Compressor
  • Thread starter Thread starter Blown 04 Roush
  • Start date Start date Jun 11, 2008
Blown 04 Roush
Pascagoula, MS
Jun 11, 2008
  • Jun 11, 2008
The compressor on my '04 Roush is going out. Are the compressors from all 99-04 'stangs the same. Or was there a difference between the years, or maybe between v6's and v8's? Also, could you use the compressor that comes in the 4.6 crown vic's? I'm clueless.... Any suggestions?
the98stang
2,408
Clovis, CA
Jun 12, 2008
  • Jun 12, 2008
I'm sure all 99-04 compressors are the same. The Crown Vic compressor might be different, I'm not totally sure on that one.
Either way, I wouldn't get a used one....
Blown 04 Roush
Pascagoula, MS
Jun 12, 2008
  • Jun 12, 2008
Any idea how much they are new???
the98stang
2,408
Clovis, CA
Jun 12, 2008
  • Jun 12, 2008
2-$300
But you have to have the freon removed before you can install a new one. It's best to let the AC shop handle it.
Are you 100% sure the compressor is done? It might be the pressure switch or some other issue.
Blown 04 Roush
Pascagoula, MS
Jun 12, 2008
  • Jun 12, 2008
Well I don't think it's the whole compressor, but isn't there a clutch or something in it. See what happened is a had a period when I rode with the a/c on and windows down and now you can here the compressor kick on and start to make a rattling sound (repeats very often). The reason I know it's the a/c is because when you turn the a/c off, the rattling is continuous and doesn't stop.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jun 12, 2008
  • Jun 12, 2008
Here ya go:
Cougar '97 8-280 (4.6L)
Lincoln Mark Series '97-98
Mustang '97-04 8-260 (4.6L)
Mustang '05-06 4.6L (3V)
Thunderbird '97 8-280 (4.6L)
Blown 04 Roush
Pascagoula, MS
Jun 12, 2008
  • Jun 12, 2008
Those ALL work on our cars?
BobHyatt
378
  • Jun 12, 2008
There are actually more than that. Ford uses that standard 4-bolt thru the compressor to the block method on some trucks as well.
Last such compressor I bought was for $166 at Advanced, it was a new compressor complete with clutch, but needing PAG oil before installation...
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jun 13, 2008
  • Jun 13, 2008
It's the clutch. New ones are about 100. If you have the tools you can swap it out.
http://forums.stangnet.com/showthread.php?t=614300&highlight=compressor+clutch
BobHyatt
378
#10
  • Jun 14, 2008
  • #10
COramprat said:
It's the clutch. New ones are about 150. If you have the tools you can swap it out.
The problem with that is that a complete new compressor at Advanced is $166. When the clutch goes, there is a good chance it overheated in the process, which can cause the front compressor shaft seal to leak as well. After a new clutch, you still have the leak.
The clutch is a quick install, but it might be wasted. Clutches are getting harder to find as well, probably because getting the air gap takes some time and most are not set properly causing the new clutch to fail quickly.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jun 14, 2008
#11
  • Jun 14, 2008
  • #11
The leak should be noticable and just swapping the clutch requires no evacuating the cooling system and recharge. I've had mine in with no issues for a good while. Plus I looked up the clutch and it is 100 instead of 150.
W
Will Smith
191
Cape Coral, FL
Jun 14, 2008
#12
  • Jun 14, 2008
  • #12
ford compressors are known to leak out the front seal. just make sure to see if u spot oil in the clutch insides...
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
M
  • mnky99
  • Sep 5, 2025
mnky99
M
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
