4.6 mustang GT 2000 P0340 code
sharpright
9
Mars
My car is throwing a P0340 camshaft position sensor A circuit bank 1 or single sensor code.
The forums say it is most likely the alternator but when engine is running the voltage across the battery reads 14.3V. With headlights (low beam), wipers full speed, heater fan on max, rear defroster, no radio the voltage drops to 14.0 V.
The resistance reading from alternator positive to alternator body or mounting screw (ground) reads ‘0L’ meaning the diode is good. Alternator looks ok.
Is it likely that my sensor is probably bad? Or is there anything else I can check?
The car occasionally does give a slight jerk in fifth gear at high speed/high load when pressing the accelerator hard. The error code always comes at highway speeds and hot engine.
Freeze frame read
Fuelsys1 = CL
fuelsys2 = NA
load % = 8.6
Engine temp = 178
Short fuel trim 1 % = 11.7
Short fuel trim 2 % = 7.0
Long fuel trim 1 % = 5.5
Long fuel trim 2 % = 6.3
RPM = 2443
Thanks
View: https://www.youtube.com/watch?v=LFKL990i0bE
Apparently you can have good voltage; but because of a bad diode in the alternator / you can get frequency pulses (noise) that create havoc in your camshaft position sensor circuit. That can be verified with $100 diagnostic test, or take the money and take your chances on a new alternator.
Let us know what happens.
Looks like it might have been just the camshaft sensor. Replaced it and no problems so far. Will post back if the problem happens again.
Reactions: McFly2
