  • SN95 4.6L Mustang Tech
Engine 4.6 Oil Pan Differences Gt, Mark Viii, Town Car
  • Thread starter Thread starter jruppert
  • Start date Start date Jan 4, 2015
jruppert
294
Michigan
Jan 4, 2015
  • Jan 4, 2015
Hello,
I have a question about 4.6 oil pan differences between these cars. I am aware that the Mark VIII oil pan has a baffle attached to the side of the oil pan. Well, at least some of the years.
I have a 97 Mark VIII parts car that I bought to use for an AC Cobra project that I am working on. I was told by previous owner that the pan was replaced and used an oil pan from a Town Car. I have to assume these are the same as Crown Vic as well. So I got under there the other day to look around and have compared what I saw to Crown Vic pans online.
So is there much difference in oil capacity between the Town Car and GT/Cobra? I will probably want to retain the low oil sensor that was used in the Mark. Not sure if this pan has provisions for it.
My biggest concern is the pick up and dipstick. If the pan was changed to a Crown Vic/Town Car setup, would the pickup be different? Would the dipstick be different?
If I need to swap to a GT pan then that is fine. Just need to know if its necessary. As for clearance, the frame that I am working with has plenty of room.
Thanks
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jan 5, 2015
  • Jan 5, 2015
Think about it. The dipstick is the same because it's the level below the rotating crank that matters.
In direct answer to your question. The Mustang oil pan has a slightly larger capacity (+1 quart).
In my case when I swaped in the Crown Vic Romeo into my 2000 GT, I re-used the Mustang Oil pan.
Regardless of which oil pan is used, it's a good idea to CONFIRM that the clearance between the oil pick up and the bottom of the pan is correct.
jruppert
294
Michigan
Jan 5, 2015
  • Jan 5, 2015
I guess my thoughts were if a smaller pan was used then it would make the dipstick appear like it has 6 qts when in fact it might only have 5 qts. But maybe I am looking at it wrong. I have never torn apart a 4.6 so that is why I wondered about the pick up. Thanks
bhuff30
6,037
35
129
Olathe KS
Jan 12, 2015
  • Jan 12, 2015
Is this motor going in a factory five cobra replica? If so, be aware that you need an aftermarket pan which is shallower. Otherwise, the stock pan hangs below the frame and that's just asking for trouble. I, wouldn't be surprised if this is true for other manufacturers too.
I am building a factory five mk4 with the coyote and had to get a shallower pan as well.
jruppert
294
Michigan
Jan 12, 2015
  • Jan 12, 2015
No this engine will be going into a Streetbeasts model. The frame is completely open under the engine and oil pan.
bhuff30
6,037
35
129
Olathe KS
Jan 12, 2015
  • Jan 12, 2015
Right, it sounds like the pan won't interfere with the frame, but will it hang below the frame? If the oil pan hangs below the frame, it is likely to be torn up by road debris, rocks, ect and could lead to catastrophic engine failure if it gets torn/damaged. Just something to check and be aware there are shallow pans out there for the modular engine.
jruppert
294
Michigan
Jan 12, 2015
  • Jan 12, 2015
Thats a good point.. I have yet to set the motor into the frame. Still working on getting the engine out of the mark viii. After that, I will need to come up with some motor mounts. I wonder if I should look into putting a shield in front of the pan.
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
D
Resolved Oil pan welds cracking
  • D & D Racing
  • May 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 16, 2025
revhead347
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
Front sump oil pan with dipstick
  • 2stroke1971
  • Jul 14, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 15, 2024
AeroCoupe
