4.6 problems in my Saleen!
toby1ton
so i just put a motor in my saleen and i got it all wired up and all figured out. but now there is a weird knocking sound comming from the top end. it sounds like a lifter is not primed up.
the check engine light was on so went though it
P1445- Purge Flow Sensor circuit Input High- still working on it.
P0340- Camshaft Position Sensor Circuit Malfunction fixed
P0171- System too Lean (Bank 1) fixed so far
the oil psi is good. it did not get hot
the car is all stock with bbk cold air and 30 pound injectors.
i have a complete vortech set up for it and apr cold air with 42pound ingectors and mass i want to put it on when its running good
any ideas??? is there a way to prime the lifters ive let it run for a while and still no change
