  • SN95 4.6L Mustang Tech
4.6l SOHC interchange?
  • Thread starter Thread starter puTTs
  • Start date Start date May 25, 2004
P
puTTs
10
Randolph, OHIO
May 25, 2004
  • May 25, 2004
The short block in my brothers 4.6l SOHC Mustang(manual) is completely wasted. I have a chance to get a 4.6l SOHC out of a '95 thunderbird(auto). Will the short block from the Tbird bolt into the mustang? Will the t-5 trans bolt on to the '95 tbird motor that was originally an AUTO? Will the heads off the mustang bolt on to the tbirds short block? Basicaly will the tbirds motor be a direct drop in replacement for the mustang? Sorry I don't know much about these Fords. I can't even figure out why they are called a "MODULAR" motor... Thanks, puTTs.
forpit2000gt
2,490
Columbia, SC
May 25, 2004
  • May 25, 2004
what year Mustang? They should bolt up ,that is why it is called modular. You can bolt differnt heads and intakes for different cars on to the block. I am not sure but I believe that some of the early 4.6 blocks do have a little differnt castings for transmissions. I don't know which years.
GoBabyVroommm
1,156
Chicago, For Realss???!!!
May 25, 2004
  • May 25, 2004
I don't see a problem. It should all bolt up. With the trans just put the fly wheel and clutch on.
brandon_lawson7
239
Morehead, KY
May 25, 2004
  • May 25, 2004
I know what your goin thru. My engine went out and Im installing another 4.6 out of a 95 crown vic. The guy who sold me the engine said that it will hook up just fine. Im using the manifold and other useful parts off of my old engine. So your brother's should be just fine.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 26, 2004
  • May 26, 2004
the only blocks that had a different transmission casting were the early iron blocks in the 4.6 like 91-92 i believe that were made for the AOD not the 4r70w
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
