tried searching, but couldn't find what i was loking for. for all you guys that did the swap, do you have to change out the K-member? it might be a silly question, but i have never really looked into it.
trash the rear springs though and btw IMO eibach drag springs feel the same as just 4 cyl springs for the rear and 1 coil taller v8 spring in the front. My car has a ***got stance now
HMM, I have never heard anyone ask that question. If no one has an answer for you I would just take measurements for depth and what not. Then, as long as the bolt pattern is the same then it should bolt right up. I highly doubt it will work but honestly.. I have seen stranger things. sorry I was of no help whatsoever LOL
no the bellhousing for a 4 banger and v8 is different mainly due to the position of the clutch fork and i belive the bolt pattern is different too,you have to have a bell off of a v8 in order for everything to work.you will also have to change the pilot shaft bearing in the back of the crank for the v8 to accept the smaller dia. input shaft on the 4cyl tranny.
