4 cylinder t5 pilot bearing
DouglasOhio
116
Canton Ohio
first where do i get one, second is the bearing itself bigger or does the whole housing that goes into the assend of the crank need to be replaced. I got the bearing itself out but not the housing and need to know if i need to get the housing itself out or if the 4 cyl just uses a bigger bearing. My v8 t5 blew up and im putting a spare 4 cyl in. thanks guys.
I've heard of a bunch of different bearings, but I'm about to do the same thing and I have the bearing from an 84 ranger diesel I believe. Part number is 14672 that you can get from Autozone, it's like 10 or 11 bucks, you can also get one off ebay. Go to corral.net, I know if you search there for "pilot bearing four cylinder" it will come up with a bunch of results. I know the inside diameter is smaller and the outside is the same size as the for 5 liter
