Be careful with your front wheel selection. The 96 spindles will push out your front wheels
Yeah, I'd thought I'd read that... he said he had some 94 stuff for sure but thought these were 96...are they different?
96+ are a few mils longer then the 94-95 stuff. If you are running bigs and littles it really won't be a problem. However if you want to run 17X9's you might have some trouble. Also, the 96+ stuff is supposed to cause bump steer problems, although there are more then a few people around here that are running the newer spindles and don't have a problem.
lotta ghey talk around here...
Ok...a buddy of mine is telling me he's got stuff I can have *free*to convert to five lug with rear disc, but I want to still be able to clear 15 inch drag lites for track duty.. I believe the rear brakes are lincoln mark..front are 96 gt(not sure about front) will they clear? what rotor diameter can I go to and not have clearance issues?![]()
Kick Guy out![]()
WUT?!?!Youre the one hoping dudes will look at your dirt star when you bend over![]()
and you do this
....so anybody have an answer as to what size brakes will still fit under 15 inch draglites?
13" cobra brakes will fit
3" wheel studs
1 inch spacer...
round off front edge of caliper
