4 speed to 5 speed help
  • Thread starter Thread starter minivan
  • Start date Start date Jun 13, 2009
M
minivan
eugene OR
Jun 13, 2009
  • Jun 13, 2009
84 LX 5 litre.. Has a factory 4 speed.. Would changing it over to a 5 speed be a bolt in affair?? Seems as if the 5 speed was an option that year.. Thanks for any help..
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 13, 2009
  • Jun 13, 2009
If you use a Tremec 3550, Tremec TKO , Tremec 500 or 600, you just swap the transmission. These Tremecs will bolt right up to your existing bellhousing. A Tremec from one of these models is nearly indestructible if you keep it lubricated properly.
A T5 will require a different bellhousing from the one currently bolted to your 4 speed. T5's won't take to speed shifting and you should prepared for it to break if you drive it really hard.
M
minivan
eugene OR
Jun 13, 2009
  • Jun 13, 2009
thanks for the help...
What exactly is my 4 speed?? and is it any good??
And can you tell me the difference in the 3550 vs. the TKO vs. the 500 vs. the 600?? I remember toploaders, muncies, T 10, and 833', but I am old school.. Can you school me on the newer stuff??
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 14, 2009
  • Jun 14, 2009
The Tremec 3550 family includes the 3550, TKO, 500 and 600. The 3550 is a drop in for the setup you have now. Look for a used one and you might find a bargain that will shift good and take anything you can throw at it.
The case is the same on all of the 3550 family, but as you go up the list, the torque handling capacity increases and some of the gear ratios change. The TKO, 500 and 600 use a different transmission yoke, and the TKO and 600 use a 26 spline input shaft that requires a 10.5 Chevy disk. See TTC: TREMEC Transmissions for more information.
I_AM_CANADIAN
189
B.C.
Jun 14, 2009
  • Jun 14, 2009
You currently have an SROD (single rail overdrive) transmission. From a performance standpoint, they suck. Parts are getting hard to find for them, and they are not stout. For mileage purposes, they beat any other 4 speed out there.
93 LX
3,081
Norwalk, CA.
Jun 15, 2009
  • Jun 15, 2009
I made the swap back in the mid 80's on my 82 Capri. Its still alive and while power shifting is hard on them if you have a good firewall adjustor and a good clutch they will hold up ok. I have never broken it and its been this want since 84 or 85. So if your going to keep your 4 eyed stang and want the advantages of OD then its a slam dunk. I just got the entier tranny, bell housing with the tranny and bolted it in. As for the drive shaft i did replace the yoke but that wasn't for the transmission swap it was due to a grooved yoke from the SROD tranny when it broke.
M
minivan
eugene OR
Jun 15, 2009
  • Jun 15, 2009
Did you go with the T-5 or a tremec?? thanks for all the help everyone..
93 LX
3,081
Norwalk, CA.
Jun 15, 2009
  • Jun 15, 2009
Tremec Trannys werent popular at that time. I still have the T-5 I installed back then still running hard in the Capri!
F
FoxChasis
20+ Year Stangneter
Dec 23, 2003
590
277
93
Jun 21, 2009
  • Jun 21, 2009
There was no SROD in '84. Last model year for that four-speed manual transmission was '83. The T5 was standard in the '83 model year (starting when it first became available....December of '82) and the SROD was optional.
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
J
1998 v6 5-speed automatic transmission
  • Jude Thaddeus 1
  • Jan 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 21, 2026
