408 W EFI Setup
  • Thread starter Thread starter gdog87
  • Start date Start date Dec 27, 2011
gdog87
Menlo Park
Dec 27, 2011
  • Dec 27, 2011
Hey guys new to the forum, and im trying to figure out some things for my project that im going to be getting underway. The project will be going into a 71' or under mustang, and im trying to get an idea of how to run my 408w motor EFI. Its not been built yet but i just bought the CNC 351W bored for a 408 stroker kit, and im trying to figure out if there a special company that can make you special harnesses IE if you have a electic waterpump, fuel pump, injectors, distributor etc.?
If you need more questions answered id be happy to answer
Thanks for any help you can provide
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Dec 27, 2011
  • Dec 27, 2011
First question. Do you want to go with a Mass Air or a Speed Density system ?
gdog87
Menlo Park
Dec 28, 2011
  • Dec 28, 2011
most likely id like to go with a mass air system
Rick 91GT
Mustang Master
95
99
PA
Dec 28, 2011
  • Dec 28, 2011
Stock latemodel computer (will have the chip or piggyback to tune) or are you looking for full adjustability?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Dec 28, 2011
  • Dec 28, 2011
I think an A9 series ECU with a quarter horse is a good choice. You will need to get some bigger injectors and a new MAF which is calibrated properly.
gdog87
Menlo Park
Dec 28, 2011
  • Dec 28, 2011
deffinatley looking for something with full adjustability. My issue isnt really the ECU as it is where to get a wiring harness to put all of this together.
gdog87
Menlo Park
Dec 28, 2011
  • Dec 28, 2011
Is the brand A9?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Dec 28, 2011
  • Dec 28, 2011
A9 is the ECU family. Ford made a lot of 5.0 ECUs and the A9L/A9P are the most commonly tuned 5.0 ECU. What is your budget ? You can buy an entire EFI harness from Painless but it isn't cheap. You can get them off Ebay or other forums as well. Ford didn't put mass air in the trucks until much later but if you just use the 5.0 ECU its fine as long as you get a base tune for the ECU before you run the motor.
gdog87
Menlo Park
Dec 29, 2011
  • Dec 29, 2011
DO you think that going with a painless harness in the end though would be the easisest? Do they make custom harnesses based on your information on what your trying to do/ electronics your trying to incorporate?
Hack
1,945
Minneapolis
Dec 29, 2011
#10
  • Dec 29, 2011
  • #10
It depends on what you are doing with the motor and your degree of patience with learning and tinkering. If it's NA and you aren't going to be constantly upgrading the A9 Ford computer with a chip should work. I would recommend just paying someone to burn a chip for you if that is your path. If you want to do nitrous or boost and you don't mind spending the money FAST would be be the best do it yourself option IMO. Not the bottom dollar FAST EZ EFI computers - those self-learn and you can't really tweak them much. Yes, an 80s-90s Ford ECU with an aftermarket chip added can allow you to adjust using Moates or other software, but from what I've read the learning curve is very steep. I spent some time looking into it. I'm an engineer, so I do like tech, but it seemed like a lot of reading, research and learning to me. More time and fussing than I would want to do. If you have the patience to spend months or possibly years learning the details of a program and tweaking things for driveability - definitely do the Moates. However, remember if you make a tuning mistake you could end up killing your engine. It could be an expensive mistake!
I'm building a 408 Cleveland that will be EFI. I'm just planning to have a local company burn a chip for me. I think it's $300-350 range. I'll use the A9 Ford ECU and the Ford EFI harness that's designed for adding the A9 ECU to a hot rod. One thing I don't love about the Ford EFI harness is I don't think the wires are long enough - they don't provide enough flexibility in where to mount the computer. I used the harness originally to convert an '83 Mustang to EFI, and it was tight to get the computer under the dash on the passenger kick panel. Using the A9 ECU with an aftermarket chip won't give me adjustability I can do myself, but my motor will be NA. I shouldn't need a lot of adjustability. The 80s Ford ECUs actually are pretty good at self-adjusting and handling changes to the motor like heads, cam etc. as long as it's nothing too crazy. If I really need to I can go back to the guy who burned the chip for me and have him do a new tune. Typically they will let you come back for adjustments as part of the original package deal. I don't think you can incorporate a knock sensor or pull timing under boost into the EEC IV models - so if you want those features the A9 ECUs are probably not right for you. Then I think you'll want to step up to FAST, which costs a lot more but will be a lot more flexible. If it were me I would just wire in the extra electrical parts yourself as part of a new wiring harness. Just buy a somewhat generic wiring harness from American Autowire or Painless that has enough capacity for the circuits you want. I think the American Autowire classic update models have the extra circuits but still fit our cars. I haven't gotten that far in my research yet.
I'm planning to use a carb intake and a Duraspark distributor when I break in the flat tappet cam, then put the inner valve springs back into the heads, install the EFI intake and wiring, tow the car to the tuner, and have him do the chip. My EFI distributor will be a modified part from a 460. If you go Ford you can use something from a 351W out of a 90s pickup, I believe. The tuner will do a couple re-burns to the programming as part of the deal. It's a lot of extra work to break in the cam - I wish I would have gone roller!
Rick 91GT
Mustang Master
95
99
PA
Dec 29, 2011
#11
  • Dec 29, 2011
  • #11
I think the first thing that needs to be done is determine your budget and narrow down what system you want. FAST makes a complete harness for there unit, Big Stuff 3 would also be a excellent choice. Where are you located? The reason I ask is if you go with a unit like one of those I mention you want to make sure someone in your area can tune it.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Dec 29, 2011
#12
  • Dec 29, 2011
  • #12
Rick, good call on the budget question.
I have used the painless harness in my friend's 68. They have an option for extra long wiring so you can put the ECU where you want it. It isn't cheap but it comes complete with only the plugs you need for engine management.
Using a stock harness from a donor car is the cheapest way to go but you will end up with a bunch of extra plugs that you wont use and will need to remove manually if you don't want them hanging around.
If you can find someone in your area who will tune the Moats Quarterhorse it is the best way to go using a stock Ford ECU. You can also tune it yourself later if you want to learn it in the long run.
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
L
Microsquirt pnp from EFI Source Timing setup issues
  • Lemonjohn92
  • Feb 7, 2021
  • Digital Self-tuning Forum
4K
Digital Self-tuning Forum Feb 18, 2021
a91what
M
408 Stroker build (what heads)
  • Mach1969
  • Feb 9, 2020
14K
1965 - 1973 Classic Mustangs -General/Talk- Feb 13, 2020
08GT500
J
*New guy* Microsquirt questions regarding required engine info.
  • jack.stand.racing
  • Sep 23, 2020
3K
Digital Self-tuning Forum Sep 24, 2020
jack.stand.racing
J
