Deadly97snake.. your combo is very close to what I have being built right now from Bennett Racing. just on a side note the sportman block is on back order and Bennett is offering the dart block for 1100 more right now. Anyways. Heres what I'm doing
Dart block all forged 418 from Bennett 9:1 compression ready for boost
Bennett custom cam (hydrolic roller wild side of street 6800 shift point)
Dart Pro 1 225 cnc'd heads put together by Bennett
Kooks 1 7/8 or 2" headers
Victor Jr intake, ported and converted to EFI ( He said not to use the super spyder on this application)
Pro M 92 mm maf
90 mm throttle body converted to 87-93 wiring.
42 lb injectors (these are more than fine with the lower bsfc of a N/A engine
AJE K member for added clearance
my Viper T56
Mcleod Twin street dual disc clutch and flywheel. Very pricey but will hold 1200 hp and feels like stock. McLeod said 550-600 hp on a single disc will work for a while but will burn out premature. I over killed it in anticipation of the blower. it's an awesome set up.
This is a combination that I have gone over with John at Bennett and with 9:1 compression Bennett is saying upwards of 550-585 fwhp N/A and is capable of 1200 with boost. Would easily go more n/a if I wanted to bump the compression. I wouldn't bother with the 1 3/4 headers.. I'd go atleast 1 7/8 then 3" all the way back. If your going to use a power adder I'd go 2" Kooks. From what I'm learning these motors definetly like things big. I would probably invest in a decent fuel system, lines, rails, and pumps as well.
Definetly give John a call at Bennett.. He will give you real world advice and work with a set up that meets your needs.. And from what I've heard from a Leading Pro 5.0 racer that uses them. they are top notch.
And how ever much cash you figure it's going to take to do it, add a couple grand too it.
