I have been looking into putting in a 408ci engine with AFR 205's, and a T56 tranny. I put together a parts list for this and this is what I've come up with so far...BTW the list is kinda long, sorry.
1. Trickflow Intake 351W: 351 (5.8L) Windsor 90 mm manifold, black powdercoated upper TFS-51511006 :$584.40 www.jdsperformance.com
2. Headers: MAC 1.75" HTS coated
Part Number: TF7792
Price: 299.99 http://www.mustangwarehouse.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=1&Category_Code=351L3
3. Throttle Body: Accufab: Ford Throttle Body Only Race 90mm Code: F90
Price: $257.99 http://www.mustangwarehouse.com/mustang_1.mvc?p=F90&Category_Code=AC
4. MAF
ro-M 92MM for 42# injectors N/A $425.00 http://www.pro-flow.com/Pro-M meter_Gallery.htm
http://pro-flow.com/Price Dealer Order/pricelist2003.htm
5. Heads: AFR 205's
6. Injectors: 42# part# FMS-M9593F302, from Ford racing $399.95 www.summitracing.com
7. Cam: Custom Hydraulic Roller cam 279.00 (www.Bennettracing.com)
8. T-Rex: Universal, 50 gph at 70 psi rating, T-Rex fuel pump Part # VOR-8F002-265 $189.95 (summit)
9. Fuel pump: 255LPH:Walbro Ford High Performance Fuel Pump/Kit
255 LPH High Pressure $109 (jds)
10. Transmition: Tremec Viper-Ford T-56 (http://ddperformance.com/T56 Kits.htm)
11. Suspention: Maximum motorsports "The Launch Box" Part# LB-5 Price:$3,370.98 http://www.maximummotorsports.com/giab3.asp
12. Pro-Billet Distributor: 351W, aluminum housing, polished finish, Street series: Part# MSD-8478 $259.95
13. SPORTSMAN 351 TO 418 CID SHORTBLOCK $4595
The Sportsman 351 Shortblock is a solid choice for anyone wanting to make 900 or less horsepower.
FRPP 6010-A351 SPORTSMAN BLOCK PRO MACHINED
SCAT FORGED STEEL CRANKSHAFT-BALANCED
SCAT H BEAM FORGED STEEL CONNECTING RODS
CUSTOM ROSS or CP PISTONS & HD PINS
CLEVITE H SERIES BEARINGS
SPEEDPRO MOLY OR HI TEMP RING SET
FELPRO REAR MAIN SEAL
PRO ASSEMBLED
*ADD $325 FOR MAIN SUPPORT SYSTEM & MAIN STUDS
*ADD $459 FOR CUSTOM GRIND ROLLER CAM,ARP CAM BOLT,TIMING CHAIN,ROLLER CAM RETAINER, and CAM DEGREED
Part Number: TF7792
4. MAF
ro-M 92MM for 42# injectors N/A $425.00 http://www.pro-flow.com/Pro-M meter_Gallery.htmhttp://pro-flow.com/Price Dealer Order/pricelist2003.htm
5. Heads: AFR 205's
PRO ASSEMBLED
