Ok well the bottem end of my motor has been assembled for some time now, but nothing is torqued down yet. I will be buying my cam/lifters/rockers/pushrods soon, so i wanted to get the bottem end out of the way. I was just wondering what are the torque specs for the maincaps on a '74 351w. I have seen 2 or 3 differents specs so far, it has studs instead of bolts so i can put my main girdle on, not sure if that would change anything. I aslo would like to know the rods specs too. Thanks guys.
The Torque Specs i found so far is....
Main Bearing Caps: 60-70 ft-lbs
Connecting Rods: 40-45 ft-lbs
-AJ
-AJ
