408W from the Engine Factory or Keith Kraft?
  • Thread starter Thread starter Cannoball888
  • Start date Start date Dec 9, 2006
Which is the better engine for street and occasional track??
  • Engine factory 408W with Vic Jr heads and intake, and larger cam
    Votes: 1 9.1%
  • Keith Craft standard 408W crate
    Votes: 9 81.8%
  • Other (explain)
    Votes: 1 9.1%
  • Total voters
    11
  • Poll closed Dec 9, 2007.
Cannoball888
320
Gainesville, FL
Dec 9, 2006
  • Dec 9, 2006
I've looked at about a half dozen crate engine builders and have narrowed it down to two. They both are about the same price. Which is the better one? The one from the Engine Factory I would have them sub with the Vic Jr heads and intake and a larger cam.
Engine Factory 408W crate
Keith Craft Standard 408W crate
E
entdoc
89
greenville, SC
Dec 9, 2006
  • Dec 9, 2006
I would go with Craft
coolblue65
1,224
Algonquin, IL
Dec 9, 2006
  • Dec 9, 2006
I really like DSS, I have been planning on a new motor for awhile, and I am planning on going with them. I have yet to hear any negative opinions on them.
http://dssracing.com/
xoxbxfx
3,959
Southlake, TX
Dec 9, 2006
  • Dec 9, 2006
Do some research...I have read many bad things abou them and Coast High.
I personally would go with Keith Kraft.... They are local to me and I know of a few people running their motors with no problems.
R
Robdogg67
148
Seattle/Tacoma, WA
Dec 10, 2006
  • Dec 10, 2006
Another vote for KC, most all the others are "me-too's" with same or similar components. They do not have the experience or longstanding reputation and you cannot me-too that either. In 5-10 years KC will still be there like he has for 20+ no question, others will fall out for sure as the market tightens.
Assumming both are equal price wise with apples to apples stuff, I would go with KC even if the others offered a warranty.
coolblue65
1,224
Algonquin, IL
Dec 10, 2006
  • Dec 10, 2006
Really? I have heard plenty of bad things about Coast, but never anything about DSS - is there anything specific about them? I suppose I will have to do some more digging.
xoxbxfx
3,959
Southlake, TX
Dec 11, 2006
  • Dec 11, 2006
man..I have heard lots of things over the years and cant honestly tell you anything specific...just been to long since I have even thought about them. Sad to say, Im not really into the mustang thing anymore... I just pop in once and a while to drop my $.02
66HertzClone
428
Central New Jersey
Dec 11, 2006
  • Dec 11, 2006
I had a problem with the stroker I bought from KC. A head gasket failed after about 500 miles worth of driving. When I took it apart I found they had used those graphite Ford head gaskets, and when checked we found the gasket was thicker by .012" at the upper head bolts than the lower bolts. The machine shop said this indicated improper torque.
I also found rusty sediment in the engine, it looked like the boil process was skipped. I was unable to remove the drain plugs from the block, two tools were broken in the process. I ended up making a vacuum like tool with small diameter tubing that I could slide into the holes for the water jacket and suck the sediment out of the block. I kept the sediment as a souvenir and even thought of sending a sample to KC.
While I did all the work other than a pressure test of the heads, the repair cost me $280.00 in parts. All I wanted from them was to cover the costs I incurred. They denied any responsibility and offered to send me replacement head gaskets, this saved me about $100 of the total, had they agreed to the total I would not have even replied to this. I spent over 7K for the motor and a dyno run with them, in my opinion they should have stood up and taken responsibility, just thought you would want to know.
Cannoball888
320
Gainesville, FL
Dec 11, 2006
  • Dec 11, 2006
Wow, you're the first I have read about having had a problem with KC. I guess all the builders have some bad examples. I'll just have to choose the one which I think has the best record. However, I still think it's KC so far.
GoinBroke
109
Joliet, Il
Dec 11, 2006
#10
  • Dec 11, 2006
  • #10
Does any of your local builders offer a warranty? I just have completed the breakin on my 408 I had sourced locally from a builder and could not say better things about the service. I supplied him the block, the rotating assembly and other parts (except heads) and he completed the engine from there. I picked it up and after installing it in my car he came to my house and did the initial firing and the cam breakin.
I have visited him twice since for checkups and carb tuning at no charge also. His normal engine warranty for general service cars is 12 month/12k. His builds like mine he warranties to not leak, use oil or smoke for 6 months since most people run them at the strip mostly.
Just food for thought.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 11, 2006
#11
  • Dec 11, 2006
  • #11
If you have the facilities to assemble an engine yourself, I would look into getting everything done seperately and assembling it myself. Crate engines are cenvenient, but you can't personally be sure everything is right unless it holds togehter or something breaks.
67FBack
316
New Braunfels, TX
Dec 16, 2006
#12
  • Dec 16, 2006
  • #12
Another vote for KC. I have never seen Keith not back up his products without a solid reason. Not to say your reason is not valid.
F
FullRace
41
#13
  • Dec 16, 2006
  • #13
Do the work yourself, and youll have a better motor. If you think your not capable, ask someone who might now or buy a book. Just take your time. Why would anyone buy a crate motor?
Cannoball888
320
Gainesville, FL
Dec 17, 2006
#14
  • Dec 17, 2006
  • #14
For people like myself who would rather be driving than spending all free time in the garage.
Cannoball888
320
Gainesville, FL
Dec 17, 2006
#15
  • Dec 17, 2006
  • #15
double post
65ShelbyClone
4,675
38
119
Dec 17, 2006
#16
  • Dec 17, 2006
  • #16
Or those who perhaps lack the tools, garage space(apartments & condos), or even the physical mobility/ability to do it.
I lack none of those, but often I do in the budget area, so I try to save money by doing the labor myself.
H
hurst1979olds
#17
  • Mar 20, 2012
  • #17
I purchased an engine from Engine Factory for my truck. I did a long research with different crate engine companies. The Engine Factory, Matt and Bruce, is absolutely amazing.
They built the engine for my needs, I am towing my Harley once in a while. Also when you have questions, they will have an answer for you!
Get the matching March serpentine system also, it not only looks great but works even better. The engine is hot tested and runs right out... of the box. Everybody who has seen it so far is just wowed. I wanted a daily driver I can depend on and that is what I got.
This was one of the best decisions I made on the truck!
Good luck, give them a call you will not regret it.Gunther
http://enginefactory.com/letters.htm
J
Fox body - godzilla, coyote, or 408w stroker - Best route for budget build?
  • jaygee15
  • Jan 27, 2025
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2025
2000xp8
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
P
New to StangNET
  • Popeye1790
  • Apr 19, 2024
  • The Welcome Wagon
The Welcome Wagon Apr 19, 2024
Popeye1790
P
