408w fuel system
  • Thread starter Thread starter sneakyD
  • Start date Start date Jan 24, 2008
sneakyD
12
  • Jan 24, 2008
i have a 408w- hydraulic .523 .523cam, steel crank and heads (windsor sr.), forged rods and pistons.
what do yall think of this- should i run #10 from cell to pump, #8 from pump to regulator, #8from regulator to carb? i do plan on spraying down the road. i was told by a local mustang shop i might wanna run #10 from the cell to the pump to keep fuel supplied to the pump. is this necesary?
this kit seems like a pretty good deal. comments...
http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS-641520&N=700+0&autoview=sku
carb recommendations? car is not a dd but im trying to keep it as street friendly as possible because 80% of driving is on street. barry grant seems expensive, is it worth it? iwas trying to stick to holley. also, i'll be running a dual plane intake.
thanks for the help
PUNISHER RACING
1,124
FORD CITY, PA.
Jan 24, 2008
  • Jan 24, 2008
Line size sounds perfect, that kit could be built cheaper.
sneakyD
12
  • Jan 26, 2008
anyone else who is running a 408w what is your setup? carb, intake, fuel system, susp, tranny, e.t.s?
ChromdOutDubs
268
Tavares, Florida
Jan 27, 2008
  • Jan 27, 2008
Im running -10 from tank to my aeromotive filter and aeromotive pump, then 1/2 alum hardline from pump to aeromotive regulator, then dual -10 from regulator to the Quickfuel 750 carb. Can post some pics of more info on the aeromotive stuff if you need it.
-AJ
sneakyD
12
  • Jan 28, 2008
pics would be great. are you using stock tank or cell?
real clean hatch!
ChromdOutDubs
268
Tavares, Florida
Jan 28, 2008
  • Jan 28, 2008
real clean hatch!
Thanks, im using the stock tank, but i sumped it with dual -10 fitting. One is feeding the pump one is capped... Lemme go snap some pictures for ya.
-AJ
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
  • dan50
  • Jul 18, 2026
dan50
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
