4cyl to 5.0 conversion tach problem
bronco4x4
43
fall river, ma
I have a 85 Mustang. The original tach is way off. Whats the easiest way to correct it? I dont want to use a aftermarket tach at all, i want the original look. Ive heard there may be a switch on the tach itself, but who knows. Ive also thought maybe taking off the needle and setting it where its supposed to be? Thanks
All my pre 87 stangs had the switch. Take the panel off in front of the cluster and you will see a switch that says 4/6/8.Turn to 8 and you are good to go.
