4cyl to 5.0 conversion...
  • Thread starter Thread starter mhorn0817
  • Start date Start date Apr 15, 2008
M
mhorn0817
69
  • Apr 15, 2008
hey everybody, i just picked up a 87 mustang coupe this weekend that was originally a 4 cyl but the guy did a 5.0 swap...and now that ive got it and looking closer at it im not sure if we was finished or not or what...theres 2 vac ports on the throttle body open , not pluged or have lines running anywhere...the upper intake manifold has a vac line coming out the bottom of it but just has a screw in it to cap it off....a maf conversion was done. just curious how i do the dual o2 sensors or if i even need them, it was running open opens and he gave me a catless x pipe and flowmaster with dumps, i put them on last night, its not 100% done but it hangs to low and scraped on a 1 inch bump...is there a v8 swap right up and or pictures somewhere that could help me out, or is anybody in MD that feels like coming over and looking at my mess? thanks for the help in advance!!
mustangfan1990
505
Lenoir, North Carolina
Apr 15, 2008
  • Apr 15, 2008
well if it fuel injected def need the 02s sensors. As far as teh TB are you sure that the 2 ports arent water passages on the spacer? if so plug them. There should be 1 vaccum port on top of the TB that goes to the filler neck in the valve cover.
M
mhorn0817
69
  • Apr 15, 2008
ok since i need the 02 sensors, what am i supposed to do to hook them up? im guessing the original 4 cyl only had the one connector, im not sure if its right or ot, i really didnt evn notice any connectors buti wasnt looking to had either becuas i was trying to figue out the exhuast
im ot sure baout the ports on the TB, they ae 2 very small ports which is why i assume they are vac ports but ill take a closer look after work.
also i noticed, about a half inch tube running behind the motor but on the driver side its been cut, whats that and do i need it?
blueblazes
76
  • Apr 15, 2008
the 02 harness is different and should plug in to the 5.0 harness around the right fender area on the stock harness you definately need the 2 o2 sensors
stykthyn
5,232
2,652
223
gainesville
Apr 15, 2008
  • Apr 15, 2008
if he did an efi swap then he had no choice than to use the correct harness and the 02 plugs should be in the fender area like said. as long as there are no vacuum leaks I would plug off the unused stubs and remove any extra hoses to clean the area up.
posting pics of your engine would be a good idea in helping decide what's what.
M
mhorn0817
69
  • Apr 15, 2008
havnt found the o2 sensor connectors yet...im goin to post pics soon of engine bay.if anybody wants any certain pics or angles let me know. camera died as i went to load them. the motor runs and revs good and no CEL light without them pluged in.
the 2 ports on TB are on the spacer and i dont feeel any VAC so i will plug them. now there is 3 ports on the back of the upper manifold and the one in the middle is not pluged or ran and is leaking air , what should i do about that. the port on the front of upper manifold is also pluged. is that right?
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Apr 15, 2008
  • Apr 15, 2008
I could sit here and tell you what all the vacuum lines are and where they should be connected, but I feel like we'd be wasting energy because it sounds like you have a lot of cleanup work on your hands from a poor V8 conversion job. The best thing for you to do right now is look up wiring and vacuum line diagrams using the search function on here, and just spend some time making sure that everything is in place and accounted for.
Here is a web page with some VERY USEFUL information (haha) that you will need to properly go about finding the problems with your car.
http://www.veryuseful.com/mustang/tech/engine/#Diagrams
Good luck! :SNSign:
M
mhorn0817
69
  • Apr 15, 2008
i cant figure out how to post pics...any help
M
mhorn0817
69
  • Apr 17, 2008
i have pics of my motor, will someone post them up for me please
T
tim_lemmy
94
#10
  • Apr 17, 2008
  • #10
email them to blemay@unitedenertech.com and i'll get them up for you
M
mhorn0817
69
#11
  • Apr 17, 2008
  • #11
great thank you, youll have thm around 530pm. about 5 hours. thank you!
M
mhorn0817
69
#12
  • Apr 17, 2008
  • #12
ok i found the o2 sensor connectors....they are in front of the motor by the crank...they must be ran the wrong way or something becuase there is absolutely no way for them to reach the the o2 sensor. what should i do?
M
mhorn0817
69
#13
  • Apr 18, 2008
  • #13
and i just notced something else thats weird...i cant fnd a fuse box anywhere in the car or under hood. what in theworld could be up with that?
M
mhorn0817
69
#14
  • Apr 19, 2008
  • #14
ttt
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
P
Engine Vac line help on a 1985 5.0 carbed stock engine - smog lines removed
  • philcore3
  • Nov 26, 2024
Fox 5.0 Mustang Tech May 18, 2025
General karthief
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
