About halfway thru the swap and ran into some problems. I tried searching but this isn't exactly a common swap so I came up empty-handed.
I didn't get any instruction on what to do here and we have no clue. Hopefully I can find some insight here. I'd *like* to get some work done on this tomorrow (if not finish, ugh) but of course I can't talk to my builder until Monday. So:
1. The AOD I took out has the shifter lever pointed DOWN as mounted on the transmission; the new 4R has it pointed UP. The AOD has a stud & flats design for the shift cable and the 4R has a ball/socket type attachment. Did my builder mess up the pieces here, or am I supposed to do something I'm unaware of?
2. There's a 4-pin connector that came off of my AOD. My 4R has a sensor with 5 wires in it, for SS1, SS2, SS1/2 ground, TCC and I believe TCC ground. Now we have no instruction on which wires are supposed to go where ON MY CAR, nor have we been able to dig up a schematic to my 92 to figure out what each pin on the 4-pin connector is for. If we had that, we could figure out how to make the harnesses work with each other.
3. Should I need a Trans. Range Sensor or a connector for it?
4. Regarding the sensor on the speedo gear casing. On the stock AOD I have a sensor that plugs into a harness of the car. I believe it's for cruise control. It's piggybacked off of the setup that the speedo tooth gear slips onto before going into the transmission housing. On the 4R, there's a similar connector already in place elsewhere. Should I connect the harness from my car into the provision already on the 4R or should I piggyback it like it was in the first place? If not in the stock location, why the difference?
Thanks for any help!!
