5.0 / 5.1L stroker kits for the 4.6
Stroking a 4.6L is pointless in most applications until you maximize the bore. The maximum bore you can go on an aluminum block is 3.7", this will give you 304 CI or 5.0L. Max bore on a iron block safely is .020 over or 3.572", this will give you 4.7L or 283 CI of displacement.
Modular Performance is a bit cheaper on the Big-Bore than VT and as good, if not better.
I will look for the article but what I remember was using stock heads/cams/intake the stroker lost power compared to the stock displaced motor but the Big-Bore made quite a bit more. Down low in the RPMs the stroker did well compared to the stock 4.6 setup, but the Big-Bore matched the stroker down low.
droptopponynj said:
how does a stroker fare on a engine with ported heads, cams, intake, full exhaust tune etc?
you'll gain power. maybe not the greatest hp per $ value tho. the only time the stroker/bore shortblocks hurt are when they are N/A with stock heads.
TGJ said:
They do, it is called the 5.0L Cammer and you can buy it now at just under $15000.00. The 5.0L block alone is $3100.00, which is the 3.7" Bore BTW.
well, ya. i mean 5.0 moduler as standard GT engine.
this is way i think Ford should have done.
5.0 SOHC V-8 for GT @ around 300hp
5.0 DOHC for Mach1 @ around 330hp
5.8 SOHC for Kebra @ around 360hp
5.8 DOHC S/C for 03 Kebra @ around 425hp
wouldn't that have been nice???
