What modifications will I need to put an a 5.0 and AOD in a 65 galaxy conv. It will be carb but what will I need to get them to fit in the car. I want to avoid as much fabrication as possible.
well the motor certainly will fit... as long as its got small block mounts it should be easy (i think some/most galaxies came with 289s... but all my friends have various big blocks so i dunno). Likewise for the AOD, might need to alter the driveshaft, also might need a custom crossmember. Space isn't the issue, mounting them is.
The windsor-fox site has some good info on their site in the "frequently asked questions" area that you might want to check out. http://www.windsor-fox.com/
