Hello, Im new to posting on this forum but ive lurking around for a little while looking at all the good info there is on here. I haven't been able to find anything for this problem though...
The motor is a 92 5.0, mods are: E7 heads, ported and milled with compression bumped to about 9.8:1, GT40 intake, bbk headers, Pro products FPR and a e303 cam.
My problem is this, I have an AEM UEGO wideband, it took place of bank 2 o2 sensor and im currently running the analog output to send the signal to the ecu. ( im using the P0 calibration on the gauge), At random times, The engine will lean out pretty bad, ( The idle note even changes). And just as random as it happens, it then goes back to stoich. I found out that raising fuel pressure actaully helps the engine stay out of lean, but didnt actually fix it, fuel pressure it now at 55psi with the vacuum line disconnected and about 40 with it connected. No air leaks either. Any ideas??
My other problem, after driving the car for a while with light to medium throttle, once I get on it (WOT) it will slightly stumble. After the first pull, at WOT, the pulls start getting more clear until it wont break up at all anymore. Any ideas on this?
Thanks guys!
-Jon
Thanks guys!
-Jon
