B broncodave68 New Member Jul 31, 2018 2 0 1 Bend, OR Aug 24, 2018 #1 Aug 24, 2018 #1 I did a engine swap into my Bronco, 5.0 ho 93 mustang, has svo heads. rough idle, runs rich. all new sensors installed when I did the swap.
General karthief wonder how much it would cost to ship you a pair 5 Year Member Aug 25, 2016 27,872 10,542 203 polk county florida Aug 24, 2018 #2 Aug 24, 2018 #2 Are you efi? If so do you have the obd test connector?
B broncodave68 New Member Jul 31, 2018 2 0 1 Bend, OR Aug 27, 2018 #3 Aug 27, 2018 #3 did a scan and the only codes that came up was tps out of range, adjusted it to .999 volts, then tried plus and minus a few tenths. not much improvement.
General karthief wonder how much it would cost to ship you a pair 5 Year Member Aug 25, 2016 27,872 10,542 203 polk county florida Aug 27, 2018 #4 Aug 27, 2018 #4 Take the battery cable of for 20 minutes or so and let the computer reset, then drive it around for an hour or more the check for codes again,
