5.0 engine ticking when cold
  • Thread starter Thread starter Juicer
  • Start date Start date Feb 5, 2007
J
Juicer
37
  • Feb 5, 2007
i noticed that my engine likes to tick when its cold. the ticking is very obvious. once it warms up after running for about 7 minutes the ticking stops. i notice it coming frm the passenger side. could i be having lifter problems? what confuses me is that once the engine is warm the ticking stops.
89streetbeast
365
horton,ks
Feb 5, 2007
  • Feb 5, 2007
what grade of oil are you using?
J
Juicer
37
  • Feb 5, 2007
I use 20/50.
89streetbeast
365
horton,ks
Feb 5, 2007
  • Feb 5, 2007
i would try either a 5w30 or 10w30 oil . the 20/50 oil is better for warmer climates and may be the reason your hearing the valvetrain tick. if you go with a synthetic oil i always used Mobile1 10w30 in the 89, worked great all year round.
J
Juicer
37
  • Feb 5, 2007
well its lately it has been rather warm in so cal. maybe in the high 70s low 80s and it is still ticking. it had never done it before and ive always used 20/50 with no problems. the ticking sound is pretty loud. if the car is off maybe for a few hours the ticking starts again until it wams up. i also notice that when i turn left it gets louder. i was thinking that it may possibly be my starter.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Feb 5, 2007
  • Feb 5, 2007
LIFTERS
its the lifters. it takes awhile for them to pump up. and the reason you hear them get louder when you turn left is like you said the noise is coming from the left side and when you turn left all the oil goes to the right and the lifters lose oil and decompress.
J
Juicer
37
  • Feb 5, 2007
so should i just replace them with a set of stock lifters or a set of aftermaket lifters?
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Feb 5, 2007
  • Feb 5, 2007
lifters
stock lifters should work. never heard of the stock lifters giving up but if its a chance to upgrade.. why not?
M
MustangOwner
Banned
Dec 13, 2006
160
  • Feb 5, 2007
Change your oil and put in a thicker or heavier oil. We get that alot at the body shop i work at, its normally cause they have the wrong weight oil in, not enough oil.
Jaswir
578
Orlando, FL
Feb 5, 2007
#10
  • Feb 5, 2007
  • #10
could be a exhaust leak... i thought i had a lifter tick turned out to be a header gasket!
J
Juicer
37
#11
  • Feb 5, 2007
  • #11
well it also turns out now that i have a very severe screaching noise, really loud, so loud that people down the street looked at me as if my car was about to blow or something. one girl hurried up at a stop sign to cross the crosswalk when i made a stop at a stop sign it was funny. also i was driving down the road when a very bad tapping noise almost as if something was about to come loose and break off. i felt the vibration at my shifter. it sounded and felt like it was bouncing as it was spinning. the funny thing is that all this calms down after a while but it starts again. i'm still having trouble pinpointing where its coming from. the funny thing is that there is absolutely no loss in performance, or oil pressure or overheating...nothing. i blame my starter because sometimes the starter fails to turn the engine the first time. could it be that my starter is loose with broken teeth on the starter or flywheel? or could it be both lifters and starters or could it also be my oil pump? i will have to pinpoint it tomorrow and take it to the shop. im so confused
J
Juicer
37
#12
  • Feb 6, 2007
  • #12
update
well it turns out that it wasnt my lifters after all...it was my starter. i checked it this morning and it was completely loose and ready to fall off. i tightened it enough to drive it down to the shop and had the starter replaced with a new autolite starter. everything is back to normal now. my car will be up for sale pretty soon.
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
W
2003 Mustang GT issues
  • westberry23
  • Aug 25, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
9
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
