Update.
Well, couldn't swap on 1993 SSp's coil. Somehow the tip got busted off the coil plug, so i couldn't use it. Unfortunately i found this out after spending 30 mins getting the old coil out.
I used this website, which gave the following procedure to test the coil
TFI TESTING
So i'll be doing that this afternoon. I didn't have a meter with me when i was with the car yesterday
So, i tested the resistances of the TFI and 2 other TFI's i got at the boneyard. My TFI is an A1A type...so i assume it's 21-years old and original. The junkyard TFI i got was an A2A module, so i assume it's newer. I also found a parts store TFI on an '86 GT at the yard.
So, i compared to given values from the website above
The aftermarket TFI's numbers are WAY off and significantly lower.
So, i assume if the module was bad, some of these resistance numbers would be way off? I'm kinda thinking of going to advanced...testing the A2A module and trying that out on my car.
I drove the car Sat after cleaning the Accell coil up and reinstalling it. The hesitation above 4000RPM is still there. I watched the tach and it doesn't jump or dance around at all. The car just feels like when it hits 4000, it hesitates, then goes, or hesitates completely to redline. It's def losing some power up top.
I watched my FP gauge and it stayed steady.
PS. The car has never stalled on me nor shut off when it gets hot...so i don't have the normal TFI symptoms. There are no metal shavings or anything inside the dizzy
TFI TESTING
We should now test the coil. Use an ohm meter and probe the resistance of the teo small terminals, and you should find 0.3 to 1.0 ohm. If the resistance is not ok, it may be a bad coil. If the resistance is ok, probe one small terminal and the coil wire terminal. Resistance should be 8000 to 11,500 ohms. If the resistance is not ok, replace coil. If the resistance is ok, go to step 5.
So the two motorcraft TFI's i have are higher than the given test values, and the A2A module is slightly lower in resistance than the module on my car.TFI RESISTANCE Terminals to jump Resistance (OHMS)
D1 to H1 12.8K
D1 to H2 17.4K
D1 to H3 1000
D1 to H4 11.5K
D1 to H5 4.2K
D1 to H6 0.0K
D2 to H1 1.2K
D2 to H2 5.8K
D2 to H3 12.6K
D2 to H4 100
D2 to H5 15.8K
D2 to H6 11.6K
D3 to H1 100
D3 to H2 4.7K
D3 to H3 13.7K
D3 to H4 1200
D3 to H5 16.9K
D3 to H6 12.7K
D1 to D2 11.5K
D1 to D3 12.6K
D2 to D3 1100
My 1988 TFI (Motorcraft E6SF-12a297-A1A)
D1 to H1 14.2K
D1 to H2 18.8K
D1 to H3 996
D1 to H4 13.0K
D1 to H5 3.17K
D1 to H6 0.0K
D2 to H1 1.19K
D2 to H2 5.78K
D2 to H3 13.69K
D2 to H4 85
D2 to H5 16.96K
D2 to H6 12.83K
D3 to H1 100
D3 to H2 4.68K
D3 to H3 15.05K
D3 to H4 1180
D3 to H5 18.2K
D3 to H6 14.06K
D1 to D2 13.1K
D1 to D3 14.2K
D2 to D3 1102
Junyard TFI Motorcraft (E6SF-12A297-A2A)
D1 to H1 13.97K
D1 to H2 18.5K
D1 to H3 995
D1 to H4 12.7K
D1 to H5 4.16K
D1 to H6 0.0K
D2 to H1 1.19K
D2 to H2 5.77K
D2 to H3 13.78K
D2 to H4 85
D2 to H5 16.5K
D2 to H6 12.47K
D3 to H1 98
D3 to H2 4.67K
D3 to H3 14.97K
D3 to H4 1180
D3 to H5 18.17K
D3 to H6 13.7K
D1 to D2 12.8K
D1 to D3 13.8K
D2 to D3 1102
Aftermarket TFI (from boneyard)
D1 to H1 12.3K
D1 to H2 16.7K
D1 to H3 963
D1 to H4 11.1K
D1 to H5 4.0K
D1 to H6 0.0K
D2 to H1 1.1K
D2 to H2 5.6K
D2 to H3 11.0K
D2 to H4 87
D2 to H5 13.5K
D2 to H6 9.9K
D3 to H1 97
D3 to H2 4.5K
D3 to H3 14.1K
D3 to H4 1130
D3 to H5 13.8K
D3 to H6 13.4K
D1 to D2 11.2K
D1 to D3 12.2K
D2 to D3 1058
