  • Thread starter Thread starter Jax97cobra
  • Start date Start date Jan 25, 2004
J
Jax97cobra
38
Jacksonville,FL
Jan 25, 2004
  • Jan 25, 2004
just bought a 94 with the following mods dss pro bullet short block 10:1 comp ratio, trick flow heads,trick flow track heat intake, pro m 80 mm maf,30lb injectors,3.73 gears,anderson fms b 31 cam, tremec 3550 tranny, adjustable fuel pres reg,
underdrive pullies,fms hamonic balencer,diablo chi[p,mac long tubes,mac off road h and flows
i seem to be having some probs with it though.
it seems to be very rich while idleing and burns alot of gas
stalls frequently while idling after the car has been moving
only ran a 14.076 quarter but that is partially due to the 225 tires in the rear
the car seems to have plenty of power just wondering if the quarter mile time seems decent for the amt of mods. also had a .5 reaction time on the 14 sec run but had a .104 rt later in the day but missed 3rd so it screwed up my time
67efivert
348
lincolnton nc
Jan 25, 2004
  • Jan 25, 2004
is the mass air meter calibrated to the injectors would make it too rich and slow it down
J
Jax97cobra
38
Jacksonville,FL
Jan 25, 2004
  • Jan 25, 2004
i think it is but is there anyway i could check??
it also has a flickering check engine light which i beleive to be the egr or tps
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jan 25, 2004
  • Jan 25, 2004
Well I would check and to see if the Maf is calculated for the injectors (don't know how...sorry man)...I'm sure there is some sort of number on the MAF maybe?...
Also your time doesn't matter on your reaction time....that is only if you are bracket racing...
Your car should get you real close to 12.5 with some good driving...and tuning obviously...
David
Jason 302
685
71
68
Newark, Ohio
Jan 25, 2004
  • Jan 25, 2004
What was your mph? That car should be much quicker than that, sounds like you some street slicks. And that car would probably run better with 24 lb injectors, unless you have N20 hooked up.
J
Jax97cobra
38
Jacksonville,FL
Jan 25, 2004
  • Jan 25, 2004
it ran at 104 mph having alot of probs keeping traction though.
the anderson b 31 cam recomends 30lb injectors.
SilverBullit
221
Tulsa, OK
Jan 25, 2004
  • Jan 25, 2004
If the MAM is a Pro-M it should say what size injectors it is calibrated to on the meter below the "Pro-M" letters on the sensor.
Casey
Jason 302
685
71
68
Newark, Ohio
Jan 26, 2004
  • Jan 26, 2004
I always went on horsepower levels when choosing injectors size rather than cam choice. Who told you that, the previous owner or AFM? You said she's rich at idle and makes me think those 30#'s are a little too big. But, could probably make them work cause you would have to spend $400 to convert it to 24#'s. I say turn your pressure down a little bit and check your TPS and timing. Or, if you can, find a chassis dyno and find out what your A/F ratio is.
J
Jax97cobra
38
Jacksonville,FL
Jan 27, 2004
  • Jan 27, 2004
thanks for all the help i am going to have racer walsh take a look at it....
i also talk to some1 else about the prob and they said the 94-95 have probs idling once mods are done to the motor.
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
F
1993 Cobra flooding
  • FireFoxCobra_SVT93
  • May 20, 2022
6K
Fox 5.0 Mustang Tech Mar 11, 2023
nickyb
Engine Cam idle and timing questions - big cam, little knowledge
  • Justin87
  • Jul 6, 2021
12K
Fox 5.0 Mustang Tech Jul 31, 2021
Middleagecrisis
M
SOLD For Sale 92 Mustang Notchback Complete Rebuild in 2019
  • pearlnotchback
  • Jun 21, 2021
4K
Fox Body Mustangs For Sale (1979-93) Jun 24, 2021
Steel1
