5.4 3v swap vs FRPP Boss
  • Thread starter Thread starter BluDevil
  • Start date Start date Jan 22, 2011
BluDevil
12
MO
Jan 22, 2011
  • Jan 22, 2011
Hello this is my first post on this forum and was wanting to know if anyone has had experience with either putting a 5.4 3v, or a Boss block in a 2005 up Mustang. Any advice is appreciated as I am at a dilemma as which way to go.
JymboSlice
385
Jan 22, 2011
  • Jan 22, 2011
go with the 5.4 3v with ported heads, a set of cams, and headers. just get a cheap 5.4 out of a smashed truck or on ebay or somewhere.
BluDevil
12
MO
Jan 22, 2011
  • Jan 22, 2011
Ya thats what I was thinkin if I went that route. I know the blocks are iron rather than aluminum, do they add alot of weight up front? I couldnt find anywhere that said how much the engine weighs.
AvalancheSVT
573
37
49
Jan 22, 2011
  • Jan 22, 2011
the Gt500 iron block will prolly weigh at least 200lbs more than the new 5.0 (if not more since i think it weighs like 150lbs more than the aluminum version).
BluDevil
12
MO
Jan 22, 2011
  • Jan 22, 2011
Ya I think your pretty close on the weight, just read that for every 100 pounds you save thats 10 hp gained. Startin to look like I might go with the Boss and just bore and stroke it out to a 336. I think that block weighs 165 pounds, which isnt to bad I guess. Last thing I want is my car to be super nose heavy.
JymboSlice
385
Jan 23, 2011
  • Jan 23, 2011
you could just run (if not already installing) a kmember, with tubular a-arms and coil over kit. plus a battery relocate and a tubular radiator support to remove some weight off of the front end of your 'stang if you do decide to go with the 5.4. personally id go with the 5.4 3 valve, cause its probably going to be cheaper i think? but a stroked boss is always cool
SpartaPerformance
2,517
61
89
Long Island NY
Jan 23, 2011
  • Jan 23, 2011
I disagree, it's not going to be cheaper because you'll have to buy all the part's you mentioned.
retfr8flyr
154
  • Jan 26, 2011
It will be a lot cheaper in the long run to go with a big bore block setup than the 5.4. If you go with the 5.4 and 3v heads the intake manifold and exhaust headers will have to be custom made and some of the other accessories may not fit correctly either. If you want to go 5.4 then go with the 4v GT500 setup, that way you can use everything made for the GT500 including the computer and harness. There have been several guys that have swapped in the GT500 5.4 without any problems but a 5.4 3v would be a big pain.
Earl
BluDevil
12
MO
Jan 26, 2011
  • Jan 26, 2011
Thanks for the input, ya I wasnt sure on the exhaust part. Dont feel like spendin a ton of money on headers and other parts especially if theres a chance of not fitting right.
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Am I crazy? Dad looking to buy 69 as daily
  • stonerCPA
  • Oct 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 18, 2026
nickyb
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
G
Supercharger Options 5.4 32V Intech
  • Germangazguzzler
  • Apr 19, 2025
  • Other Auto Tech
Other Auto Tech Apr 23, 2025
RaggedGT
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
