95% finished
sorry guys, i said the stock hood fits. well, it doesn't, but not by much.
i had to make a 3/4" plate to raise the TB . it doesn't clear the manifold.
it was enough to set it over the top. so i will purchase a 2.5" cobra "R" hood. i really thought it was going to clear it. oh well. i tried to make it a sleeper.
this was not really that bad a fit.
instructions to get it in are long.
all hoses need to be made.
wiring harness needs to be modified slightly
oil pan and pick up need to be changed/modified
custom headers/exhaust
air conditioner line need to be moved.
fuel rails/lines need to be made. (for 99-04 just longer line from pump)
for 96-98 brackets for ignition coils/oil reservoir for pump need to be made.
adapter from 78mm intake to 96-04 upper intake fab.
3/4" spacer for upper intake fab.
pin wheel for TDC#1 modified on passenger side intead of driver's side.
block inlet for EGR.
use all sensors and connections from 4.6
exact header fab is for sale. very expensive and time consuming to make.
i am going to make and patent this kit. exact prices in the future. i am going to continue to try designs to get this under stock hood. low profile TB/elbow is in the works.
let you guy know when i get it started. details are all that is left.
lower water hose
probably need a two core radiator. gonna put two tranny coolers to reduce the btu load on it. it is labeled to use on 302. 330 is at least close.
oil feed hose for brakes/steering
connect leed to starter.
lengthen TDC cam leads
lengthen IAbypass control leads
ground it
flywheel/converter nuts.
fuel rail bracket fab
start it.
lower water hose
ground it
start it.
