5 lug brake lines
rockingchair69
23
Alright guys I have a few questions I was hoping that someone could explain to me what a banjo bolt is I've never seen one before. I also need to know what brake hoses to use fox or sn-95. What do I do about my ebrake what cable should I use. What hoses do I need for the rear. I was also wondering about steering rack what are the best years to use and what are the best years of tie rod ends to use. thanks
Banjo Bolts are the bolts that hold your brake lines to your calipers. They have a small hole drilled through them to allow the brake fluid to pass into the caliper. I used Maximum Motorsport steel braided lines for the front and contacted ClassicTube.com who custom made the rear steel braided lines so I could use the existing hardlines and not have to cut and re-flare them.
For the parking brake cables (on 92 and earlier, '93's use a different one) you'll need two of Ford Racing # M-2809-A and one M-2810-A. The first number is the two long cables that run back to the calipers and the second one is the short one that connects them both to the parking brake handle. According to the techs at Ford Racing the flex hoses (attaching the calipers to the hardlines) that come with the Cobra conversion kit are 94-95 GT.
Here's the fun part: Starting with the parking brake handle, you're going to have to find someone who can make a small tack weld for you. Converting to rear discs on a Fox usually means defeating the self adjusting mechanism on the parking brake lever. Once the old cables are out, remove the parking brake lever and the short cable that is attached to it. The primary brake cable (the short one attached to the lever) has to be dissasembled--remove the small sheet metal bar that the two secondary (the long ones) cables were atached to and ream out the hole in the middle (11/32") to accomodate the new adjustable primary cable. The rest of the old primary won't be used, but try not to damage the rubber grommet that the primary cable passes through.
On the lever assembly you have to tack-weld the ratcheting mechanism so it won't ratchet any more. Weld the pawl (the spring-loaded toung of metal that's about two inches long, located near the base of the lever itself) to the second tooth from the front counting from the end that would be closest to the front of the car if it were installed. Install the new primary cable into the lever just as the old one came out and bolt it all back down. Then the new primary cable has to be adjusted from under the car once it is attached to the new secondary cables.
The steering rack is the same, as are the outer tie-rods, so don't worry about those. To work with SN-95 spindles the ball joints will require spacers under the spindle nuts if you keep the stock fox body ball joints, but the best thing to do is press SN-95 ball joints into your fox A-arms.
Maximum Motorsports can supply the correct front brake lines to use that will NOT require you to use an adapter on the P/S. 91-93 outer tie rod ends will have the least amount of Bump Steer.
