DirtyD916
i just got off the phone with 50resto about the 5 lug kit and they said that the rear brakes are fine and will fit almost all wheels. He said that real drums dotn have any clearance issues with any stang wheels. He just said that its the front that has the clearance issue. He said that the front grease caps are just to wide for most wheels to fit. He gave me the option of using a hammer and or grinder to slim it down and said he used that method and it worked fine for him.v8only said:that link didn't turn up anything.
problem with the 50 resto kit, is it has EXTREMELY limited wheel options. the hub is too big for most of the sn95 wheels such as the bullits, and it's essentially NOT a brake upgrade. ALL it is is lincoln rotors, and aerostar rear axleshafts. Why in hell would you want to pay that much when you could piece it together at the yards for 1/4th the cost?? The better option is the sn95 front brakes. the best years are 94/95, as it won't push your wheels out at all. I payed $75 a side at a wrecking yard. use two aerostar pass rear axles for your 5 lug in back, and bronco 2 or ranger 9 inch drums. the aerostars have ten inch drums, and you can upgrade to the bigger drums if you grab the backing plates too.
