5 lug conversion
  • Thread starter Thread starter mikestang882842
  • Start date Start date Aug 17, 2007
M
mikestang882842
  • Aug 17, 2007
just wondering who makes the best 5 lug conversion kit i was thinking about going with ford racing anybody have any suggestions
M
MustangOwner
Banned
Dec 13, 2006
160
  • Aug 17, 2007
I've had 2 "kits". i had the 50resto.com $399.99 special and the one i'm currently running now is the FRPP M-2300-K brake kit. If i was to do it all over again, i'd piece the kit together. I first bought the 50resto.com $399.99 special and installed the passenger side front rotor and thought "what am i doing? i dont want rear drums again!" so i put it all back in the box and back it went to 50resto. Then i waited a 5 month back order and finally got the FRPP M-2300-K brake kit. I installed the FRPP brake kit and everything went smoothly. It was a great kit, no doubt! But now i've become more picky, the kit comes with normal 13 inch rotors. Now i've changed those to Baer's Zinc plated rotors(they won't rust). And i've also had to install the Fox length 5 lug axles do to tire clearance. And when you swap axles you also need to buy new caliper mounting brackets. So now i've replaced axles, rotors, and caliper brackets on my brand new kit. I also didn't like the flat black calipers so i had them painted red to match my car. If i would have pieced the kit together i would have got the red calipers to begin with. So now with the price of the M-2300-k brake kit ($2300.00) and all of the different parts i had to buy because the kit came with the wrong ones for my choice, i have over $3300.00 bucks in just the brakes. Now thats just crazy. I can part together a kit WAY cheaper and have it right the first time. I hope this helps
Here is a pic of the brakes that the M-2300-K brake kit comes with. Yes they are nice, but with the different add ons i did to it such as the red calipers, Zinc plated and cross drilled and slotted 13 inch front rotors, it looks much better then this picture does. If i had a picture i'd show you, but you can imagine the difference.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Aug 17, 2007
  • Aug 17, 2007
Save a bundle and make your own kit:
http://sn95brakes.com/5lug.php
M
MustangOwner
Banned
Dec 13, 2006
160
  • Aug 17, 2007
Agreed
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Aug 18, 2007
  • Aug 18, 2007
Ford makes the best kit...but you gotta go buy it in peices and pick it up on your own to save some $$$
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Aug 18, 2007
  • Aug 18, 2007
I might be parting out my rid and can sell you my spindles, rotors calipers. I will keep ya posted. but in regards to the setup. I think you should fgiure out what rims your gonna be running first.
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Aug 18, 2007
  • Aug 18, 2007
lets use the search function..
N
niklid05
140
Kutztown PA 19530
Aug 18, 2007
  • Aug 18, 2007
junkyard makes the best kit.
LordMustangGT
118
Port Orchard, WA
Aug 18, 2007
  • Aug 18, 2007
I peiced my cobra kit together for about 1500 right off ebay!
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Aug 19, 2007
#10
  • Aug 19, 2007
  • #10
I bought my M-2300-K Kit back when they were $1700, that wasnt too bad and obviously everything in the Kit was New, but with the cost so high now its best to just piece it together.
T
Tasandmnm
#11
  • Aug 19, 2007
  • #11
Front 13 inch Cobra brakes (10th ann. red) $399
Rear 12 inch Cobra brakes $399
Front stainless hoses $80
Misc. bolts and connectors $50
SN-95 Spindles/Hubs from Corral ads $125
Brackets for rear from North Race Cars $150
Fox length axles also from NRC $190
Adj. Prop Valve and prop valve delete from MM $70
Rear Stainless brake hoses from MM $50
I am doing the conversion on a 93 Cobra so I don't need to worry about upgrading my master cylinder, most people will though so add about $100 for a SN-95 one. You could go the junk yard and/or use different parts to save some money, but if you are getting all new parts this is IMO the best way to go while spending much less than the M2300 kit.
RsStanG1987
569
9
79
Dupont PA
Aug 19, 2007
#12
  • Aug 19, 2007
  • #12
You can go the junkyard route and score the whole setup for under 200. Hell my whole rear setup was $40.. The fronts cost me about $30 and the calipers can get new off ebay for $100.
M
MustangOwner
Banned
Dec 13, 2006
160
#13
  • Aug 19, 2007
  • #13
Your also missing alot of stuff like the rear brake lines that run on the axle, all of the parking brake lines, dust shields, ALL the bolts(which there is a shi*t ton of them!), brake booster, master cylinder, rear caliper moan braces, all the fittings for the brake lines, rear caliper brackets, and a bunch of other random things like that.
Really by the time you buy all that stuff seperatly and have every piece individualy shipped from different places. I bet its damn close to the price of the M-2300-k brake kit, plus shipping on the Kit is free, and how much will the shipping be buying all those parts from dif places? alot i bet! Really its not a bad price.
T
Tasandmnm
#14
  • Aug 19, 2007
  • #14
I included the rear brake lines, bolts and fittings from PPI, rear caliper brackets from North Race Cars, and dust shields was included in my Misc stuff from PPI. Anit Moan Brackers are included with the Cobra rear brakes from PPI. In fact call up PPI and theyn set me up with EVERYTHING I needed except for: Rear Caliper Brackets and Fox Length Axles both from North Race Cars and an Adjustable Prop Valve and Rear Brake Hoses that I got from MM. That includes all the bolts and fittings from PPI. As I mentioned my 93 Cobra does not need a different master cylinder and I didnt mention that I also dont need different parking brake lines or a brake booster...but all that stuff can be had pretty cheap if I did need it.
Getting the bulk of the stuff from PPI along with the few misc. items I mentioned from North Race Cars and MM you can definitely save a bunch of money over getting the M2300K kit, I think I saved around $600 or so.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Aug 19, 2007
#15
  • Aug 19, 2007
  • #15
WOW! If you managed to find 94/95 Front Spindles with Hubs for $30 Total, then the Person did not know what they were selling to you, Good find!
RsStanG1987
569
9
79
Dupont PA
Aug 20, 2007
#16
  • Aug 20, 2007
  • #16
Local pick n pull.. 14 each plus $1 core.
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
