5 lug conversion
:shrug: just wondering who makes the best 5 lug conversion kit i was thinking about going with ford racing anybody have any suggestions
I've had 2 "kits". i had the 50resto.com $399.99 special and the one i'm currently running now is the FRPP M-2300-K brake kit. If i was to do it all over again, i'd piece the kit together. I first bought the 50resto.com $399.99 special and installed the passenger side front rotor and thought "what am i doing? i dont want rear drums again!" so i put it all back in the box and back it went to 50resto. Then i waited a 5 month back order and finally got the FRPP M-2300-K brake kit. I installed the FRPP brake kit and everything went smoothly. It was a great kit, no doubt! But now i've become more picky, the kit comes with normal 13 inch rotors. Now i've changed those to Baer's Zinc plated rotors(they won't rust). And i've also had to install the Fox length 5 lug axles do to tire clearance. And when you swap axles you also need to buy new caliper mounting brackets. So now i've replaced axles, rotors, and caliper brackets on my brand new kit. I also didn't like the flat black calipers so i had them painted red to match my car. If i would have pieced the kit together i would have got the red calipers to begin with. So now with the price of the M-2300-k brake kit ($2300.00) and all of the different parts i had to buy because the kit came with the wrong ones for my choice, i have over $3300.00 bucks in just the brakes. Now thats just crazy. I can part together a kit WAY cheaper and have it right the first time. I hope this helps
Here is a pic of the brakes that the M-2300-K brake kit comes with. Yes they are nice, but with the different add ons i did to it such as the red calipers, Zinc plated and cross drilled and slotted 13 inch front rotors, it looks much better then this picture does. If i had a picture i'd show you, but you can imagine the difference.
I bought my M-2300-K Kit back when they were $1700, that wasnt too bad and obviously everything in the Kit was New, but with the cost so high now its best to just piece it together.
Front 13 inch Cobra brakes (10th ann. red) $399
Rear 12 inch Cobra brakes $399
Front stainless hoses $80
Misc. bolts and connectors $50
SN-95 Spindles/Hubs from Corral ads $125
Brackets for rear from North Race Cars $150
Fox length axles also from NRC $190
Adj. Prop Valve and prop valve delete from MM $70
Rear Stainless brake hoses from MM $50
I am doing the conversion on a 93 Cobra so I don't need to worry about upgrading my master cylinder, most people will though so add about $100 for a SN-95 one. You could go the junk yard and/or use different parts to save some money, but if you are getting all new parts this is IMO the best way to go while spending much less than the M2300 kit.
You can go the junkyard route and score the whole setup for under 200. Hell my whole rear setup was $40.. The fronts cost me about $30 and the calipers can get new off ebay for $100.
Your also missing alot of stuff like the rear brake lines that run on the axle, all of the parking brake lines, dust shields, ALL the bolts(which there is a shi*t ton of them!), brake booster, master cylinder, rear caliper moan braces, all the fittings for the brake lines, rear caliper brackets, and a bunch of other random things like that.
Really by the time you buy all that stuff seperatly and have every piece individualy shipped from different places. I bet its damn close to the price of the M-2300-k brake kit, plus shipping on the Kit is free, and how much will the shipping be buying all those parts from dif places? alot i bet! Really its not a bad price.
I included the rear brake lines, bolts and fittings from PPI, rear caliper brackets from North Race Cars, and dust shields was included in my Misc stuff from PPI. Anit Moan Brackers are included with the Cobra rear brakes from PPI. In fact call up PPI and theyn set me up with EVERYTHING I needed except for: Rear Caliper Brackets and Fox Length Axles both from North Race Cars and an Adjustable Prop Valve and Rear Brake Hoses that I got from MM. That includes all the bolts and fittings from PPI. As I mentioned my 93 Cobra does not need a different master cylinder and I didnt mention that I also dont need different parking brake lines or a brake booster...but all that stuff can be had pretty cheap if I did need it.
Getting the bulk of the stuff from PPI along with the few misc. items I mentioned from North Race Cars and MM you can definitely save a bunch of money over getting the M2300K kit, I think I saved around $600 or so.
WOW! If you managed to find 94/95 Front Spindles with Hubs for $30 Total, then the Person did not know what they were selling to you, Good find!
