5 Lug Conversion
  • Thread starter Thread starter flyinhigh90
  • Start date Start date Nov 23, 2012
flyinhigh90
107
San Bernardino
Nov 23, 2012
  • Nov 23, 2012
whats up stangnet im trying to do the 5 lug conversion on my 90 gt im asking and looking to seee if i could go with a 94-95 gt differential any suggestions? for the front i know i can use the 94 gt spindels ...
billison
I like tinted tail
2,607
1,094
184
stl
Nov 23, 2012
  • Nov 23, 2012
I think the axles are wider, the e brake cables are different too. Google goes a long way, welcome to stangnet!
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Nov 23, 2012
  • Nov 23, 2012
It will bolt right in. You need to get the adapters, for the brake lines, convert the MC , etc. start here and all will be explained
http://www.stangnet.com/mustang-for...5-lug-brake-conversion-upgrade-thread.801400/
slow5ohgt
35
  • Nov 23, 2012
If I recall there is a certain year astrovan that uses the correct length axles which allows for a direct swap to use your existing rear for a 5 lug conversion. IMO that's the easiest way.,
Sent from my Transformer TF101 using Tapatalk 2
ratio411
3,870
73
109
Pensacola FL
Nov 24, 2012
  • Nov 24, 2012
The SN95 axles are longer.
A 94-98 rear end will make your tires move 3/4" further out.
The 99-04 rear is even wider, forgot how much...
Same with the spindles in the front.
The track width will only gain 3mm on each side with 94-95 spindles.
96-98 I believe will gain 6mm each side.
99-04 is something like 13mm per side (1/2")
Stick with the 94-95 to keep your front end alignment manageable.
ratio411
3,870
73
109
Pensacola FL
Nov 24, 2012
  • Nov 24, 2012
The problem with this method is that you need the axle from one side, the other side is incorrect length.
I forgot which side... The Areostar axles are the correct length only on one side, the Ranger is only correct on the opposite side.
So the problem you have is finding 2 rear ends to source from, 2 vehicles, not one.
Then on top of that, most yards don't allow you to pull axles because they want to sell the whole rear end, and that chance is ruined for them when you pull an axle. Then the fact you need to wreck 2 different axles...
ReefBlueHatch
682
96
39
Central KY
Nov 24, 2012
  • Nov 24, 2012
I'm not sure, but aren't 94-98 housings the same as Fox, just with longer axle shafts?
I recently installed 94-95 rear disc on my Fox housing because I had 3.73's and 5-lug Ranger axles. It wasn't hard - just a few little mods.
Cut the SN95 axle brackets to mount inside on the Fox housing
Tap and drilled a hole to mount 94-95 softline brakets
Rotor spacers from Disc Brakes R Us to use SN95 rotors on Ranger/Aerostar shafts http://www.discbrakesrus.com/make/ford/hardware.htm#axlespacer
Line adaptors Weatherhead 7818 from NAPA
Under the hood:
Used 94-95 MC
New 93 Cobra booster
Maximum Motorsports 3-2 MC line adaptor
FRPP adjustable proportioning valve
PV delete plug
dagenham
100
Duncannon PA
Nov 24, 2012
  • Nov 24, 2012
The easiest thing to do IMHO is find a donar car and take everything related to the brakes. Including the m/c, booster, and prop valve.
Reactions: A5literMan
jaketuff
159
Westchester, NY
Nov 25, 2012
  • Nov 25, 2012
Thinking of swaps...
I want to do gears on my 91 GT after the car has had a SN95 shaft swap. What gear set must be used now, SN95s or do you go with the 91 GT gearsets????
Thanks
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Nov 25, 2012
#10
  • Nov 25, 2012
  • #10
Thanks
all the 8.8 gears are the same from fox to sn to s197 to truck. theres 3 o.e. carriers (open, t-lok, and the new torsen) and two axle splines (28 and 31), but ring and pinions are the same for all and are why the 8.8 is an 8.8.
as to axles, there are aftermaket fox-length 5-lug axles available if you cant find used ranger/aerostar axles, moser, strange, and yukon all make them, and some will even use the sn hub so no ring adapters needed. and like said, depending on where you get stuff it may just be cheaper to get a whole rear from a 94-98 and swap what you need (the v6 uses a 7.5" rear, but the axles and brakes are the same as the v8's 8.8 and will bolt right on).
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
A
90 Fox 4Lug rear convert to 5 Lug
  • adimice
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
limp
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
