5 Lug Question
  • Thread starter Thread starter keith wilson
  • Start date Start date Jan 21, 2016
keith wilson
10
Southern pines nc
Jan 21, 2016
  • Jan 21, 2016
I don't know the best place to post this please help tell me where I need to post stuff like this. I can't find a tech section to post in. Anyway I'm new and have a question about my car.
I have a 5 lug swap done to my 90 lx 5.0 but I bought it like this and idk what they used for the front but it looks like the lincoln mk7 rotors and hub and looks like stock calipers as well. My question is I can get a deal on some 94 sn95 drilled and slotted rotors for the front but will they fit? If it does have the mk7 front hub and rotors will those sn95 rotors fit? And if anybody knows what the dimensions are for the 94 rotors and the mk7 rotors like what are the differences in size and back spacing and all of the two rotors. I can't find any info nowhere.
All I know is the sn95 rotors are like almost 11". The ones on my car look like about 11" and the ones I ordered for sn95 says they are like 10.87" and have a hub hole of 2.80".
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Jan 21, 2016
  • Jan 21, 2016
mk7 rotors are identical to fox rotors except they are 5 lug. To use 94 rotors you'll need 94-95 spindles which will then require you to use the better 94-95 calipers or 99-04 dual pistons if you choose to .
keith wilson
10
Southern pines nc
Jan 21, 2016
  • Jan 21, 2016
I was just hoping since mine is already 5 lug that the sn95 rotors would go on.
keith wilson
10
Southern pines nc
Jan 21, 2016
  • Jan 21, 2016
And if I do change it then if I use all the sn stuff can I use the 99 calipers with it or will I have to get the stuff from the 99-04 in order to use 99-04 dual piston calipers?
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Jan 22, 2016
  • Jan 22, 2016
99-04 stuff pushes the wheel out way to far . 94-95 spindles with the 99-04 front calipers is no issue. You just need to trim the spindle a hair to clear the caliper. With changing the calipers you will need the correct master and booster to compensate.
Mustang5L5
Mod Dude
Feb 18, 2001
43,389
18,129
224
Massachusetts
Jan 22, 2016
  • Jan 22, 2016
You've got some research ahead of you if you want to swap to SN95 stuff. Requires spindle swaps, master cylinder and booster changes, and a rear disk brake upgrade as well. The info has been covered hundreds of times and is a simple search away
Honestly, it's a lot of work to simple run drilled and slotted rotors, which look pretty but offer no braking performance upgrade at all. If your motivation to change is simply for the rotors, then it's not a good reason IMHO
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
