5 lug stainless lines
Get the fox specific lines, but you are right, you'll need the SN95 banjo bolt.
The difference between the Fox and the SN95 is where the soft line mounts to the body. The Sn95 has two different sizes each side while the Fox is the same on each side. That's why when guys install OEM Sn95 brake lines on a Fox they need to use the adapter fitting.
However all SS line use the same narror head, so they will work with any caliper really. Pick the SS lines to fit the model car you have not the model calipers you are using.
Well I did just that and got my stuff done today. It was a nightmare, but it got done. I have a little leak I have to take care of, as well as some rubbing somewhere when I stop, but I'll have to figure that out some other time.
Got the wheels on and I'll update the fox body wheel thread when I get pics and clean
