5 Lug Swap Help
dcurtis
688
Ok, I have a 91 Gt and a complete 95 V6, the V6 has a cracked block, a shattered front glass and only one good light on the whole car, anyways I was wondering what I would need off of it to convert mine to a 5 lug, I really would rather keep drum brakes out back so I won't have to change the lines or booster or anything like that. For the rear would I be better of getting the ranger or aerostar axles and just sticking them in there, or do I need more than the axles? Will I need anything else from the front that isn't on the 95?
ranger/aerostar axles and the ranger 9" drums is all you need out back
Out front, swap everything from spindles to calipers and SN95 brake lines. Used your fox struts.
Only thing you will need is a small adapter for the passenger side SN95 brake line. It's a weatherhead fitting, unsure of the number though. It's available from NAPA and i'm sure someoine else can chime in on the number
Keep the MC/Booster and rear brakes at least. You can sell them off or maybe down the line you can install them. It's not that tough.
If anyone knows the part number for the passenger side line adapter please post, as for the rest of the car, minus the master cylinder, brake booster and the complete rear end I am either gonna junk yard it or part it out, the interior is perfect other than the driver seat, its al black and red. But I need that part number please.
