5-lug swap specifics
02silverbullet
I my car has a 91 lx front end and 84 rear axle.
car body is actually a 84 ltd II with all the 91 suspension, engine trans dash etc.
I need the specifics of why to not use the newer spindles to do the 5 lug swap. I understand they move the wheels out further but the only people who seem to have clearence issues are the ones using 9" wide wheels up front i will be using the 01 gt 5 spoke 17"x8" wheels with 245/45/17 tires.
I have heard the newer calipers are better (aluminum and 2 piston) that is why i would rather use the newer front spindles.
Also what is required to swap the rear from drums to disks, is this do able with junk yard parts on my axle, (caliper brackets, axles, backing paltes, etc) or is something custom needed?
as my car sits now it tucks the stock 10 hole wheels with 245/60-15 like 1/8" up inside the fender at static ride height
bump, anyone? i need to buy parts this week i would like to have this car on the road by this weekend! :)
here is a shot of the car and the wheels i want to use
Use 94 or 95 spindle if you can. they keep you closer to stock trak.with the99 up pbr caliper.As for the rear alot of companys sell brackets to put on your axle. Or use a complete lincoln lsc or mustang rear
so i use the 95 outers and rotors and can convert later to the 99 and up calipers? they just bolt up? sweet!
and so will this work to swap out the rear? 95 rear from the axles out?
or will i need special brackets?
"Up for auction is a complete 5 lug rear brake setup from a 95 Mustang.
This is complete and ready to go. This auction will include the axles, rotors, calipers,parking brake cables, backing plates, and all other mounting hardware, all you need is new pads, the rotors have a little rust from sitting, the rest is pretty rust free!!"
if i use this above setup, will i need to replace the master cylinder and add remove a proportioning valve since pressure is different with drums?
I believe that if you use 94/95 spindles (like I have) and 99+ bpr calibers (like is being given to me) you have to grind a little clearance on the spindles to clear the calibers. no big deal but don't freak out when its not "bolt on" if thats the stuff you go with.
