  • 2005 - 2009 Specific Tech
5 spd vs. 5 spd
  • Thread starter Thread starter Evil SS
  • Start date Start date Oct 25, 2004
E
Evil SS
  • Oct 25, 2004
Does anyone know the gear ratios of the Auto and the manual tranny yet? I would like to see them side by side with the final drive and all. We could really come up with a conclusion on what "Should" be faster.
351CJ
1,732
  • Oct 25, 2004
T-3650 MTX ratios are: 3.38, 2.00, 1.32, 1.00, 0.62
Rear end is 3.55
5R55S ATX ratios are: 3.22, 2.29, 1.54, 1.00, 0.71
Rear end is 3.31
You have to tell us what you mean by "Faster"
0-60
1/4 mile
top speed
or ???
SadbutTrue
2,391
Thousand Oaks, California
Oct 25, 2004
  • Oct 25, 2004
It appears they will be even to 60, perhaps with a slight edge to the auto even. Tests so far have been filled with praise for the auto's lowend. Topend the Manual takes it easy, because the 4th and 5th gear in the auto are said to be mileage gears, not meant for pulling.
So far, quarter mile times are similar. I imagine the fastest times will be had with the manual, but it will be much closer than with previous mustang incarnations.
C
calypsocoral302
64
Philadelphia, PA
Oct 25, 2004
  • Oct 25, 2004
If the 4th and 5th gears in the T-3650 MTX are "mileage gears", I'm wondering how nobody (as far as I know) has yet complained about the 5th and 6th gears in the T-56 M12 in Pontiac's GTO? For reference, those are 0.74 and 0.5, respectively. The GTO's final drive is also lower than the Mustang's, at (if memory serves correctly) 3.31, with 17" tires.
Emil
90
Barrington, Illinois
Oct 26, 2004
  • Oct 26, 2004
Remember an auto has a torque converter which at lower rpms gives you a much better ratio.
nick26
37
Attleboro, MA
Oct 26, 2004
  • Oct 26, 2004
but an auto also has more driveline loss cause of the weight and overhead...
not to mention the importance of shift points
351CJ
1,732
  • Oct 26, 2004
I already covered this on one of the other GTO topics.
The GTO has a 3.46 rear end ratio (at least for the MTX, I don't know if the ATX is different).
Tires are 245/45/17, same as the SN95 Mustangs.
However since the tires on the GTO are smaller in diameter than the '05 Stang, the GTO effectively has a 3.66 rear end ratio as compared to the '05 Stang MTX. Or conversely the Stang has a 3.35 rear end compared to the GTO's 3.46 when ajusted for tire diameter. And the '05 Stang ATX has an effective rato of 3.13 compared to the GTO.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Saturday at 7:48 PM
AlexM556
A
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
wyatt-tetro891
W
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
