5 speed tranny fluid ????
You have a drain plug to drain it.
Then you have a fill plug to fill it back up.
That bullet archive link is a good place to get familiar with it. Also, everyone should have a Haynes manual. They have all the info you need for routine maint.
thanks guys and do u have to take the shifter off to fill it or can u use that bolt that comes out
You can fill the tranny by taking off the shifter which is what I do. The shifter can be a bitch to remove sometimes. Just make sure you use RTV or if you use a shifter gasket make sure its in good shape before you reinstall the shifter.
I've tried the filler plug but it gets messy sometimes and space is very limited if you're working on your back.
J
