50oz, 28oz, zero balance?
  • Thread starter Thread starter D347643
  • Start date Start date Nov 12, 2004
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Nov 12, 2004
  • Nov 12, 2004
how would you benefit by balancing your engine to zero balance, will it rev higher? just wondering
thanks
Drew
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Nov 12, 2004
  • Nov 12, 2004
I have heard and it makes sence that with a heavier bobweight at each end of the crank is hard on the berrings.
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Nov 12, 2004
  • Nov 12, 2004
the crank determines the imbalance.
the stock crank in our cars are 50 oz imbalance
most after market cranks are 28 0z imbalance.
I had my rotating assembly balanced at the mach shop before assy.
RyanSG
286
Allentown, Pa
Nov 13, 2004
  • Nov 13, 2004
i have an eagle crank rods etc. How do i know what balencer i should get. I had the stock flywheel on it. So should i just get another 50oz one? (mine is shot so i'm also looking for a new one...)
Rick 91GT
Mustang Master
95
99
PA
Nov 13, 2004
  • Nov 13, 2004
If the car was balanced using the stock flywheel then it is a 50oz.
You basically determine the balance when you have the rotating assembly balanced at the machine shop. You can balance almost any crank to 0, 28, or 50. It all depends on how much work it will need to get there.
If you use a very light rod and piston the crank may need Mallory to make up the weight to go 0. Most aftermarket strokers go to 28 becuse you do not have to remove as much material.
The new Eagle 4340 internal balance cranks will go to 0 fairly easy since they are made heavy, and you do not have to add any Mallory which gets expensive.
RyanSG
286
Allentown, Pa
Nov 13, 2004
  • Nov 13, 2004
ahh icic, so basicly since i had the stock flywheel on i should get the 50oz..... That works for me! Thanx
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
