510 Plus RWHP Marauder
Here are some pictures of the 04 Marauder we just finished, this car was bought new and we removed the stock engine and transmission, I ordered a 03 Cobra motor and sent it to Jim O'niel, he does excellent modular engine work, he removed the heads and installed better valves and springs Billet oil pump gears, ARP fasteners and FR500 cams, I installed the Marauder intake with a Vortech JT Trim, 50 pound injectors Custom fuel rails and # 8 supply line, with a custom dual Cobra fuel pump assembly thanks to Paul @ Pauls high performance. We rebuilt the transmission to Jerry W's specifications, added my Metal Matrix Drive shaft, and exhaust, we used Bear Front brakes and KVR rear brakes, This car made 510 RWHP on 12PSI when the belt started slipping it has a 17 PSI pulley so I feel the car will make close to 600 to the tires, once we convert the six rib to eight. The car has upgraded rear control arms, from my friend Zack Pauls is also ready to release there set, the car has a PI 3000 tripple disk and 4:30 gears we are going to install wider rims, since the tires are devistaed at WOT now, I will post final #'s after the 8 rib set up.
http://web.iwebcenters.com/reinhartautomotive/images/STUPS.jpg
http://web.iwebcenters.com/reinhartautomotive/images/STU04DS.jpg
http://web.iwebcenters.com/reinhartautomotive/images/STUDSBACK.jpg
