  • SN95 4.6L Mustang Tech
  • Thread starter Thread starter lazer red GTS
  • Start date Start date Apr 5, 2005
L
lazer red GTS
31
ennis
Apr 5, 2005
  • Apr 5, 2005
what would make the most noticeable difference in my nustang? im kindof limited on my money right now but just name stuff good and cheap, or even ussed stuff if u know where to get it!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 5, 2005
  • Apr 5, 2005
Free mods:
Reset computer
Remove intake air restrictor
Google will tell you how to do these...
Also, if you are looking for things to do why not try some preventitive maintenance? All the below stuff is cheap...
You could:
Change tranny fluid
Change diff fluid
Change plugs
Change oil
Set air pressure in all tires perfectly
Clean MAF, IAC, PCV pipe
Replace PCV valve
Bleed brakes
Put some Sylvania Silverstars or PIAA headlight in
Detail car until it shines like the sun
Sick96Stang
621
Gilbert, Arizona
Apr 5, 2005
  • Apr 5, 2005
TB and plenum combo isnt bad for the money, $400 for 6-8 rwhp. 180* thermo is a cheap mod that gives a little bit of hp. CAI or K&N drop in filter is also cheap only like 1-3 hp out of that though.
RedDaemon
3,470
9
108
Atlanta, GA
Apr 5, 2005
  • Apr 5, 2005
id say a plenum and tb combo as stated above..u already got the exhaust...or why not do cams for around the same?
Sick96Stang
621
Gilbert, Arizona
Apr 5, 2005
  • Apr 5, 2005
I was thinking that also but cams are decieving when it comes to price. Sure the cams are only $500-$600 but then you need springs and a tune also. Also if u dont have gears you will need those also. Its not a requirment but is highly recommended.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
What Movie Would You Make?
  • Noobz347
  • Oct 9, 2026
  • Off-Topic Hangout
Off-Topic Hangout Oct 14, 2026
DadLife0724
