Every couple months my car would stumble, sputter, die and then be fine after 30 minutes for another couple months or so. Well the car decides to do this to me on an all mustang Poker Run, embarrasing
, but atleast it finally threw me a code. What was originally presumed to be a PIP sensor on the way out turns out to be the CCRM.
I would check for power at the few pins involved, but since it is an intermittent problem I doubt I would find anything. So, I should check the wires for any cracks and breaks, but otherwise just replace the CCRM. Just want to make sure I dont go spend about $200 and then in two months get stranded at a carshow.
Thank you
, but atleast it finally threw me a code. What was originally presumed to be a PIP sensor on the way out turns out to be the CCRM.I would check for power at the few pins involved, but since it is an intermittent problem I doubt I would find anything. So, I should check the wires for any cracks and breaks, but otherwise just replace the CCRM. Just want to make sure I dont go spend about $200 and then in two months get stranded at a carshow.
Thank you
I tried to do some of the tests this morning but I had confusing results. am i supposed to probe the pins from the back of the plug while its plugged in? Or unplug and probe the pins from the front?I dont even know if thats the problem anymore, or if now I may have fried the new CCRM.
